Suspension or brake problem?
Old Mar 24, 2008 | 03:11 PM
rocketman2005's Avatar
Hi Everyone! i have an 06 cobalt ls with 91000 miles on it, i know i drive a lot, well for a little while now it pulls slightly to the right and when i brake from around 55-40 the wheel shakes and it makes clunking noises, everything other than the tires is stock and never been replaced any ideas what it could be i'm not too sure myself
Old Mar 24, 2008 | 03:13 PM
RA071623's Avatar
Sounds like your tires are worn out. Take a penny and put them in the tread head side down, if you can see all of Lincolns head you need new tires.
Old Mar 24, 2008 | 03:17 PM
rnjmur's Avatar
There are manyt hings that can cause these problems. It does sound like your rotors are warped causing the vibrations when braking. The pulling could just be cause due to being out of alignment, you do have 91,000 miles on the car it is probably due for an alignment if you haven't had one. It is alwasy possible that one of the calipers could be sticking and causing the car to pull, but if that were the case you should be burning through brakes like there is no tomorrow.
Old Mar 24, 2008 | 03:19 PM
mrsilent13's Avatar
i would say that ur rotors are warped....or alingment, like it was mentioned above....good luck
Old Mar 24, 2008 | 07:55 PM
thanks for the help guys at 91k shes probably due for new brakes anyway so i'm on my way to go get the parts now, thanks for all your help!!
well you all are geneses!!, fixed the problem great now i just need to go get an alignment.
Thanks again
Last edited by rocketman2005; Mar 24, 2008 at 07:55 PM. Reason: Automerged Doublepost
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
