suspension problem
Old Jan 20, 2008 | 09:05 PM
SilverLSJ's Avatar
suspension problem
i'm not real sure what exactly is wrong, but i think there is something wrong with my suspension. idk if its the weather, not too long ago i started noticing a weird sound coming from what sounds like my rear suspension. its been progressively getting worse. tonight was the worst its been to date. every bump i go over wether i slow down for it or not, it sounds like an old bed frame/mattress squeaking, or kinda like bad sound effects for a horror movie, haunted house floor board squeak. anyone have any ideas to what it could be? the struts or the springs? i want some kinda idea before i call my stealership.
here are the details...
its the stock suspension all around
i have 12000miles on my car, no accidents, always serviced at the dealer(just had it serviced yesterday and there were no findings from them about it), never to a track of any kind
and it was 19 degrees F when i left work today
and its almost every bump, severe or not, even expansion joints on the bridge.
Any ideas??
thanks
any thoughts at all?
Old Jan 20, 2008 | 09:20 PM
jcj08sta's Avatar
This may help
Originally Posted by fr33k
Here's ya some info from GM. It's a real common thing. It happens on both my balts.
Document ID# 1890375
2007 Chevrolet Cobalt
Subject: Noise from Rear Of Vehicle - keywords canister cold CVS click evap knock L61 LE5 noise rear solenoid tick vent #PIC4317B - (01/23/2007)
Models: 2006-2007 Saturn ION
2006-2007 Chevrolet Cobalt
2007 Pontiac G5
2005-2007 Pontiac Pursuit
with Engine RPO L61 or LE5
This PI is being superseded to update technical information. Please discard PIC4317A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A noise may be heard from the rear of vehicle; typically 3-5 knocks during initial cold start. The noise may sound like someone outside of the vehicle is tapping on the back window or on the rear exterior body panels.
Recommendation/Instructions:
This noise is from the vehicle's EVAP canister vent solenoid going through the diagnostic cleaning cycle, which is part of the software calibration set-up. Replacing the EVAP canister may not resolve the issue when the vehicle is re-exposed to a cold start. No parts should be replaced. This should be considered a normal condition for 2007 and previous model years.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed
Old Jan 21, 2008 | 05:02 PM
SilverLSJ's Avatar
according to that post it doesnt really apply to me, but thanks for the input anyways
Old Jan 23, 2008 | 07:57 AM
Deathscythe's Avatar
I changed out the springs on mine and installed coilovers. With about 18000 miles on mine I am having the same issue. Maybe some of the rear suspension parts need to be lubricated or replaced. Just my thoughts though.
Old Jan 23, 2008 | 08:01 AM
roadrage06's Avatar
i know what you're talking about. I don't know how long you've had your car, but it's just the cold.... promise.
Old Jan 23, 2008 | 08:55 AM
Mr McCabe's Avatar
Mines the same way in the cold...
Old Jan 23, 2008 | 02:18 PM
SilverLSJ's Avatar
i bought my car in december of last year, but last year was a real mild winter and it was brand new. but from what i'm hearing from my service guy its the cold. the rear shocks don't have the same viscousity in the cold. thanks to everyone for their input.
Old Jan 23, 2008 | 02:21 PM
I hope that's what the case is.
Old Jan 23, 2008 | 02:29 PM
Halfcent's Avatar
I'm old school
A sqweek alone is not a problem. If there is rattling as well, that means something is loose. The sqweek could be coming from a number of places that are effected by the cold temps. It could be the shock itself, or the rubber mount on the trailing link of the rear axle. Those kinds of parts get hard in the cold and will sqweek. Come spring when you can get under your car again, take a look at your parts and give them a good shaking and wiggling. Make sure nothing is loose. Perhaps replace your shocks while you are at it. They are fairly cheap anyway.
Old Jan 23, 2008 | 02:52 PM
I am hoping it is just the cold because I just installed a coilover system on my balt and the noise is still very much there.
Old Feb 10, 2008 | 06:25 PM
Mr McCabe's Avatar
I know this is a semi old thread now but...
I took my car into the dealer because my car was doing some serious squeeking whenever I hit a "rolling" bump (like a speed bump or a dip in the road) ANYWAYS... my service tech told me that it is most likely my control arm bushings. Apparently these cars are notorious for this problem. It will be fixed this week thank god!
Old Feb 10, 2008 | 07:49 PM
Let us know for sure if that fixes it. I will have to do the same thing then.
Old Feb 10, 2008 | 08:02 PM
Mr McCabe's Avatar
Will do!
Old Feb 14, 2008 | 10:28 AM
Mr McCabe's Avatar
A little update... it IS the control arm bushing causing the squeeking. The parts will be in sometime this week so hopefully that fixes the problem!
Old Feb 14, 2008 | 12:28 PM
awesome! good news. I will go in sometime soon and get mine looked at for the same reason.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
