Suspension Technique Sway Bars
Is this what you'r looking at?
http://www.gravanatuning.com/product...x?prod_id=3436
If so, I'd contact either gravana or Suspension Technique to know for sure. However, I'm pretty sure that most of the stuff out there are interchangable between the model levels.
I think someone covered this before, the bars are actually smaller than stock on the 2.0 SS/SC so there wouldn't really be a benefit to them. You want to go larger on sway bars.
The only model that those would upgrade to a larger dia. bar would be the 2.2. Even on the 2.4, the front would stay the same size and the rear would be smaller.
Wait for something 2.0-specific. No sense in spending money on something that's worse than what's on the car.
Originally Posted by kyyankee
Are the ones one the 2.0 solid or hollow? even if you go smaller diameter but solid would that be better than hollow wider diameter?
That being said, you MIGHT get away with smaller but stiffer bars and just a minor improvement in handling. Depends on personal preference, but you definitely wouldn't be getting the most out of the suspension with the smaller bars.
None of the anti sway bars replace the stock bar. It is welded in and not removable. The aftermarket bars add to the original bar, so they will stiffen up the axle and improve handling. This will be true on any model. I think the LT might not have a factory bar, but all others do.
Dennis
Dennis
Originally Posted by memphisr24
So wait, would it be a wise decision to buy them or no?
Dennis
Dennis
Let me tell you, I installed the Progress rear sway bar (22mm) last night and it's a MASSIVE improvement over stock. I can't believe the change in the ride! Everything feels much stronger and solid, even braking from highspeeds was less nerve wracking.
I can't say enough good things about this. I got mine for $198 CDN ($38 shipping to Canada) off eBay.
Best thing the Cobalt ever had done to it, WOW!
Ryan
Ryan
DANRICKARD
Oct 1, 2015 12:08 AM
