Sway bar??
Old Jan 16, 2009 | 04:28 PM
  #51
tdipowered's Avatar
if it is weird then you can just give it to me
Old Jan 16, 2009 | 06:04 PM
  #52
Maven's Avatar
What? who are you talking to?
Old Jan 17, 2009 | 11:38 PM
  #53
07BluBalt's Avatar
Originally Posted by Maven
If oversteer scares you, you may want to seriosuly rethink the TTR rear sway bar, especially without springs and without a larger front sway bar.
The TTR bar (even the Progress bar, just to a lesser degree)on a stock FE1 car is the definition of oversteer when it comes to Cobalts.
The TTR rear bar on a stock FE1(LS/LT) car dramatically increases the stiffness in the rear of the car(thats why everyone says you can feel it as soon as you drive the car out of your drive way) This extra stiffness tends to make the Cobalt oversteer(more correctly snap oversteer, meaning its fine until its not), which is not good on the street(as you found out) Most importantly is that since the Coby is fwd and due to the suspension design it gets another very special type of handling characteristic, its called "trailing throttle oversteer" This is basically means that if the car is oversteering, when you let go of the gas it actually oversteers MORE, it doesnt correct itself......To get trailing throttle oversteer in control you need to either have room to ride out the oversteer, or get back ON the gas....neither of these scenarios are safe or effective on public roads.
So to answer your question: Yes a large rear sway bar will make your otherwise stock car handle funny.
I'd highly recommend upgrading to the Eibach Pro-Kit or SS/SC springs as your first suspension mod. Followed later by a FRONT sway bar, and THEN a rear sway bar. It will still make your car a little tailhappy, but it wont have the tendency to snap oversteer like it will on a stock car.
Springs FTW.
This only partially true....the main 2 reasons stock Cobalts have unpredictable handling(imo) is due to the absolute crap tires they have from the factory, and because they have very little caster(Ive seen new cars with as little as 2degrees caster)
Cobalts understeer, unless you hit a mid corner bump or in some other way unload the rear tires, only then will a stock Cobalt oversteer. The sway bar makes a stock Cobalt much more consistantly oversteer, leading many people to believe it cures the wonky handling, when in fact it doesnt, it just makes it nearly impossible for the car to understeer, so all you notice is the oversteer events. A bad thing?? I think so, but many others dont. No matter what your thoughts on a loose car are there is no debating the fact that a simple bolt on sway bar(any brand) isnt goin to cure the things a stock LS/LT suffers from
SO TRUE!!!!
i just bought and instaleld the 1 inch ttr bar. i have h&r sport springs but holy hell. talk about 3 wheeeelin. im scared to drive my car at high speeds now. the thinkness of the bar is waaay to much for the suspension on the coby.... it makes everyday town driving and spirited driving fun because it nearly eliminates all body roll, buy when you wanna push it there is a brink of destruction with the back end now... my question is....is the only way to fix ita smaller bar. or could i upgrade the front sway to the FE5 front bar for some help??
Old Jan 18, 2009 | 12:25 AM
  #54
HunterKiller89's Avatar
so maven, since this thread has been ressurected, how do u feel about eibach's front and rear sway bar?
And how difficult is the front sway bar to install? if i recall, the rear is just a bolt on piece, but i think the front had to have other components removed to reach or something?
Old Jan 18, 2009 | 10:55 AM
  #55
Maven's Avatar
Yes a softer bar would help, as would installing the FE5 front bar to help balance the car out, the front bar wont reduce how stiff the rear is though, so if the back end is getting unsettled over rough pavement the front bar wont fix that, but it should help to reduce the oversteer a bit when all wheels are on the ground.
Yeah the rear bar is cake, either use some zipties as a helper support, or get a human helper, and the rear bar is less than a 20 minutes install, you dont even need to lift the car unless its dropped or youre a FB.
The front bar is much more difficult, some people drop the rear of the cradle, I dont like to do that. Pull the rear trans mount, and remove the two bolts that hold the steering gear to the frame, and youll be able to pull the bar out the passeneger wheel well. Removing the downpipe is an optional step that makes things easier.
Solaris99
28
Mar 15, 2017 01:22 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
