sway bar bushings
sway bar bushings
So I have to change my sway bar bushings and tires plus wants $130 to do them. But I'm looking at just replacing them myself or just getting the eibach one on zzp. What do you guys think I should do??
eibach front bar is fail.And changing bushings is a pita job. If the car is pre 2006 it has single bolt fixing and should be upgraded to two bolt, and thats a even larger pita job. its up to you.
its a fiddly job but not impossible. wobble 13 mm sockets and long extensions, etc, leave the bar in place undo the pillow block slide on the new bushings reassemble the block be happy. I would use a little amount of Superlube for the bushings which are split to make it easy to go on and not squeak later.
DANRICKARD
Oct 1, 2015 12:08 AM
