Sway Bar End Links
Sway Bar End Links
So after I installed my lowering springs, I COMPLETELY forgot to replace my old sway bar end links (Cobalt base model) with shorter ones because I have been working 55-60 hour weeks this past month. Well on the way to work today, POP.. there goes my passenger side end link.
So tomorrow I'm going to dig into it and replace them, but I just wanted to ask a quick question.
The end links for the SS are shorter than for the base model, correct?
My car is lowered ~2", so if I were to replace my now broken base model end links with SS end links, they should work fine because they are shorter?
Or are they the same length?
Just figured I would make sure before I go buy them and take the time to tear the old ones off only to find that the new ones are too long.
Thanks!
Thanks!
Okay.. first off, where do I get the Moog endlinks/how much are they?
Second.. how the hell do you get the endlink off the drivers side?
Luckily I broke the passenger side one, which is easy to get off. I went to take off the drivers side end link until I got the new links to put on, but the nut is so close to the control arm that I really can't get a socket in there.
Don't tell me I have to use a crescent wrench and do it by hand.. I'd much rather use my impact gun haha.
You can get the moog ones at napa and carquests I believe. They ran me 60 bux (so the same or less than GM or autozone ones...)
Powergrid FTW!
http://http://www.ottperformance.com...inks-40p92.htm
No rubber to wear out and no need for grease on these babies!
Powergrid FTW!
DANRICKARD
Oct 1, 2015 12:08 AM
