Sway Bars
The rear bar even if solid would still be softer than the TTR
Suspension Techniques also has a nice set. I have the front and the rear, just do not have the front installed yet because simply... I don't have the tools or the knowledge to do it on my own.
SS/TC is essentially same stiffness as SS/SC, Eibach is 69% stiffer
ST's front bar is same size as SS/2.4 bar(22mm), the rear bar is 19mm, smaller than even the Progress bar, as a matter of fact the Progress bar is actually about ~80% stiffer!
The front is WAY much more difficult to install than the rear. You have to jack it up, you have to remove the wheels, its like a 1.5 hour job under warranty. It can be done in your driveway with a jack and jacktands, but its not a half hour deal, including drink breaks, BS'ing with your buddy and swearing, I'd schedule 3hours for it.
No you dont have to remove it, but you really should at least remove mount bolts, otherwise its a massive PITA, FE1 bars I usually leave the gear alone and just remove DP and rear mount, FE5 or larger.....remove the bolts, its not worth the extra effort just to try and leave them in them
I got ST cuz I got a crazy deal. Someone was just looking to get rid of it and had never installed it, so I got both bars for a crazy deal.
Maybe I'll look into the other bars over the winter. You ever install a front sway?
I like personally like the idea of eibach and plan to our there sway bars. I have heard lots of great stuff and after installing them I would actually like to tell a difference.
Really? I didn't know that. I have a 2.2 so I felt the difference of the rear sway. My car is mostly daily driver but next year hoping to get into competition.
Yup, ive installed many
I like Eibach as much as the next guy, but I cant say I'd use their front bar on a daily driver.(You put on an SS/SC front and an Eibach rear and youll definitely tell the difference)
Yeh I would like to get into a little bit of autocross and most of our highways and city roads are in fairly good shape. A little stiffer for me in the front might not be that bad?
So, the front bar CAN be done with a jack, jack-stands, basic tools and an afternoon? I mean, I can generally feel my way through most stuff, but I don't want to screw anything up.. Is there any pics or a how-to for it.. I'd feel alot better on doing it if so.. I really would rather not spend 100 for someone to install it..
Yay
