Torsion bar
Old Mar 1, 2011 | 06:47 PM
boost_junkie16's Avatar
Torsion bar
Searched and couldn't really find anything. I found this picture on another form but there really wasn't any info on it. Is this a good idea? Or no?
Old Mar 1, 2011 | 06:56 PM
northvibe's Avatar
you should just get the Powell Hardcore Rear sway bar.
Old Mar 1, 2011 | 07:03 PM
Could. But I've got lots of steel kicking around and I'm pretty handy with a welder, I could build this for like $5.
Old Mar 1, 2011 | 09:39 PM
northvibe's Avatar
Then do as you wish. But unless you are an engineer and know physics of how this will affect performance and handling of the torsion beam you have no idea how it will handle
Old Mar 1, 2011 | 09:43 PM
CleanCut's Avatar
I say if u can build it for 5 bucks do it and see what happens... Worse case scenario, your out 5 bucks and a lil bit of time
Old Mar 1, 2011 | 09:49 PM
ilovecars's Avatar
i say make it. but make sure its removeable lol. ( probably already were but i just needed to say it)
Old Mar 1, 2011 | 09:56 PM
68nova200's Avatar
Im not too sure that will be as effective as the powell bar, being that it is only attached in the center section of the beam. I feel like it might actually be worse handling because only part of the bar is tightened.
Old Mar 2, 2011 | 12:28 PM
Looks like I'm gonna attempt to make something up. The car is parked at the moment with the engine pulled so it gives me lots of time to play with other stuff. I'll post some pics when/if I get it built.
Old Mar 2, 2011 | 01:01 PM
redcobalt07's Avatar
If you plan on autocrossing remember these are illegal.
Old Mar 2, 2011 | 02:13 PM
I don't track my car at all, if I do, I'll just take it off
Old Mar 2, 2011 | 08:31 PM
Wangspeed's Avatar
Don't think this is a good idea. Those levers are too short, and if you weld them into place, you're going to screw up the heat treatment of the spring steel (including the twisting beam itself). The only real option to doing something like this is just flat out replacing the bar that is currently welded into the beam. Why bother though. So much easier to just get the hardcore bar and call it a day. If you get this wrong, the beam may tear, or you'll turn it into a non-twisting axle, in which case you'll create all sorts of problems, like possibly denting a wheel, eating bushings in the shocks and beam, destroying the shocks, or god knows what else.
There are better things to tinker with.
Solaris99
28
Mar 15, 2017 01:22 PM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
