Warped Rotors?
Old Aug 27, 2008 | 09:23 AM
gtx28's Avatar
Warped Rotors?
Im looking for some input
I just changed the rims and tires on my car, and less than a day of driving the rotors appear to be warped. I changed back to the factory rims just to check and the factory rims still make the vibration. In my mind this points to the brakes being the cause of vibration.
It vibrates under moderate braking but not light and not really heavy braking only noticeable at higher speeds between 50 and 70+. The Tires I put on are 215/45zr17s bfgoodrich g-force t/a KDW NT or 2 whatever. The point is they are alot more sticky, ive done a few fast stops, and a lady cut me off then stoped short in trafic but I just thought it was odd that I put on the new rims and tires then all the sudden vibration in the front. Im just wondering if I put on the new rotors is it just going to warp in a short period of time anyhow?
Old Aug 27, 2008 | 09:25 AM
YellowLT's Avatar
Did you properly torque your wheels on? Are they factory Rotors? What CAr?
Old Aug 27, 2008 | 09:26 AM
camaromanss1992's Avatar
If you over torque your wheels it will cause your rotors to warp..
Old Aug 27, 2008 | 09:29 AM
gtx28's Avatar
torqued to 100ftlbs
factory rotors and pads
06 cobalt ls
Old Aug 27, 2008 | 09:31 AM
light'bolt's Avatar
I warped my rotors, had the same feel. I felt a slight vibration during regular breaking.
Old Aug 27, 2008 | 09:36 AM
Bl4des's Avatar
i have the same proble i hope it is the rotor i will be putting new ones in tomorrow along with new pads
Old Aug 27, 2008 | 09:42 AM
gtx28's Avatar
let me know how that works out for you. I wonder if this is covered under warranty im still in my warranty period.
Old Aug 27, 2008 | 09:54 AM
rrutter81's Avatar
rotors are replaced under bumper to bumper.
Chevrolet has the shittiest rotors out. Its not only with the cobalt but with other Chevy models as well. I was at the dealership talking about it when 4 others chimed in about how crappy they were.
Mine were warping every oil change so i just bought some drilled and slotted ones off ebay. Hasnt warped for 30,000 miles.
Old Aug 27, 2008 | 09:58 AM
originaladrian's Avatar
the cobalts have shitty shitty rotors, i warped mine when i first got the car. since they were replaced i have just been easy on the brakes and so far so good for 2+ years.
Old Aug 27, 2008 | 09:59 AM
WunSick's Avatar
These rotors SUCK. The warp with very little effort. I have only had the car one year, and i have had them machined once, and they are already ready to be replaced.
Old Aug 27, 2008 | 10:00 AM
D4u2s0t's Avatar
depends. sometimes they fix it, sometimes they call it wear and tear. my suggestion is to just get aftermarket rotors AND pads and forget about them warping.
just keep in mind, if you put new rotors, you HAVE to get new pads as well. and if you get new pads, you should have your rotors re-surfaced. NEVER put new rotors with old pads.
Old Aug 27, 2008 | 04:25 PM
ProjectBolt08's Avatar
[QUOTE=rrutter81;2793732]rotors are replaced under bumper to bumper.QUOTE]
Really? i thought that would be a wear & tear item...
Old Aug 27, 2008 | 04:29 PM
joeworkstoohard's Avatar
[QUOTE=ProjectBolt08;2795991]
it is and it isn't.... mine warped at 6k miles, and they reground them under warranty, but don't expect that if you have 20k on it.
Old Aug 27, 2008 | 04:30 PM
montecarloman's Avatar
I just changed the rims and tires on my car, and less than a day of driving the rotors appear to be warped. It vibrates under moderate braking but not light and not really heavy braking only noticeable at higher speeds between 50 and 70+. Im just wondering if I put on the new rotors is it just going to warp in a short period of time anyhow?
Sounds like they are beginning to warp. They will get worse over time and depending on how you treat them they will warp again. Hard driving with heavy braking warps rotors.
Any and all brake work is not covered under the factory warranty. They are wear and tear items that depending on mileage a manager can make a judgement call and cover them. Same goes for clutches by the way.
Old Aug 27, 2008 | 04:35 PM
Viper33884's Avatar
The stockers suck no matter how you drive. If your still under warranty it's covered for them to reface them. But I would advise you to get some after market rotors and pads to save the aggravation and bearings.
Old Aug 27, 2008 | 09:14 PM
BMC2U's Avatar
Driving style (hard braking) and increased rolling mass (larger/heavier wheels and tires) are contributors to warping rotors. If you must hammer the brakes a lot, get into the habit of stopping short and creeping forward. Laying into the brake pedal and coming to a stop with the pedal still down and holding you still spot warps the rotors. By sloooowwwlly moving forward after braking to a stop (ie, for a stop light) you better distribute the heat over the rotor instead of with pressure at one place. Just an FYI from experience. YMMV.
Old Aug 27, 2008 | 09:27 PM
Thumbs up
good advice
Old Aug 27, 2008 | 09:42 PM
rrutter81's Avatar
[QUOTE=joeworkstoohard;2796006]
dude i know people who get the performance rotors because of how shitty they are under warranty.
Old Aug 28, 2008 | 08:22 AM
[QUOTE=rrutter81;2797722]
yeah, i've seen that too. in my case, that didn't work out, but honestly, i DID get 53k out of my stock brakes.
Old Aug 28, 2008 | 08:28 AM
Bl4des's Avatar
i only got 14k miles out of mine they are not warped that bad but the rotors have deep groves in them and the rotors are worn down alot
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
riceburner
Sep 27, 2015 11:10 PM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
