Warped Rotors?
Is my car shaking when I brake at speeds 55 and up due to warped Rotors? This is really f'en annoying and i need to get this fixed... Thanks
either that or welcome to the shitty steering column club
1. steering column
2. Rotors 3. possible wheel bearing try rotors first |
I would get your rotors turned first if they can be, that's gonna be the cheapest fix. If that doesn't work try new rotors, if you only get shaking when braking, it's most likely warped rotors
Originally Posted by TommypSS/TC
(Post 6091193)
Originally Posted by bignicky1
(Post 6091200)
ya it only happens when i brake at like 55 up and its really really annoying.. would u guys recommend R1s?
i went to get mine turned and it didnt work dont have cash to get new rotors though so im just rolling around on warped ones lol
(Post 6091220)
R1s are fine rotors. You might be able to get your current ones machined so they are no longer warped and keep using those.
(Post 6091245)
already had my stock ones machined down and it stopped for a bit but not long, and what would you guys recommend with the rotors like drill/ slotted or like a blank rotor?
(Post 6091254)
ahh ok gotcha. Personally I don't recommend anything more than slotted. Drilled just takes away surface area. Blank or slotted are the way to go.
