Warped Rotors?
I would get your rotors turned first if they can be, that's gonna be the cheapest fix. If that doesn't work try new rotors, if you only get shaking when braking, it's most likely warped rotors
ya it only happens when i brake at like 55 up and its really really annoying.. would u guys recommend R1s?
already had my stock ones machined down and it stopped for a bit but not long, and what would you guys recommend with the rotors like drill/ slotted or like a blank rotor?
ahh ok gotcha. Personally I don't recommend anything more than slotted. Drilled just takes away surface area. Blank or slotted are the way to go.
DANRICKARD
Oct 1, 2015 12:08 AM
