Warped Rotors?
Old Oct 9, 2011 | 08:18 PM
bignicky1's Avatar
Warped Rotors?
Is my car shaking when I brake at speeds 55 and up due to warped Rotors? This is really f'en annoying and i need to get this fixed... Thanks
Old Oct 9, 2011 | 08:21 PM
either that or welcome to the shitty steering column club
Old Oct 9, 2011 | 08:24 PM
nhanson's Avatar
1. steering column
2. Rotors
3. possible wheel bearing
try rotors first
Old Oct 9, 2011 | 08:28 PM
TommyP's Avatar
AWD > FWD
I would get your rotors turned first if they can be, that's gonna be the cheapest fix. If that doesn't work try new rotors, if you only get shaking when braking, it's most likely warped rotors
Old Oct 9, 2011 | 08:32 PM
bignicky1's Avatar
ya it only happens when i brake at like 55 up and its really really annoying.. would u guys recommend R1s?
Old Oct 9, 2011 | 08:40 PM
TommyP's Avatar
AWD > FWD
R1s are fine rotors. You might be able to get your current ones machined so they are no longer warped and keep using those.
Old Oct 9, 2011 | 08:44 PM
znew's Avatar
i went to get mine turned and it didnt work dont have cash to get new rotors though so im just rolling around on warped ones lol
Old Oct 9, 2011 | 08:52 PM
bignicky1's Avatar
already had my stock ones machined down and it stopped for a bit but not long, and what would you guys recommend with the rotors like drill/ slotted or like a blank rotor?
Old Oct 9, 2011 | 08:55 PM
TommyP's Avatar
AWD > FWD
ahh ok gotcha. Personally I don't recommend anything more than slotted. Drilled just takes away surface area. Blank or slotted are the way to go.
Old Oct 9, 2011 | 09:03 PM
bignicky1's Avatar
u have any other suggestions for brakes?
Jan 12, 2016 12:01 AM
DANRICKARD
Oct 1, 2015 12:08 AM
riceburner
Sep 27, 2015 11:10 PM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
