will this fit
Old Oct 11, 2009 | 12:12 PM
red2006 ls's Avatar
will this fit
will eibach springs off a ion fit a balt let me know
Old Oct 11, 2009 | 06:59 PM
blackrocky's Avatar
thats a good question
Old Oct 11, 2009 | 08:10 PM
007CobaltLS's Avatar
No, they won't...I don't remember what's different for sure, but something doesn't work on them...probably the struts and front springs for sure...back could be the same, but I doubt it.
Old Oct 11, 2009 | 08:41 PM
qwikredline's Avatar
you can fit ion springs on a cobalt if you install an Ion top spring plate on the spring strut assembly. The Ion front spring is larger in diameter at the top, same as cobalt at the bottom. Rear springs are the same fit. Problem is, if you did the front conversion the assembly may not fit in the tower house....
Old Oct 14, 2009 | 12:31 PM
red2006 ls's Avatar
ok iwas thinking about cutting one coil out of the stock springs what will i get as far as lowerin and the ride should i do it
Old Oct 14, 2009 | 08:01 PM
Just suck it up and buy some aftermarket springs...DO NOT cut your springs and DO NOT buy Dropzone springs...other than that, anything that will fit is better than nothing.
You can search through the classifieds and find a used set of springs at a pretty good price...
If you can't afford aftermarket, then just get a set of SS/TC springs, they go for cheap and are a little lower than factory.
Old Oct 14, 2009 | 10:58 PM
red2006 ls's Avatar
how much lower will the ss springs lower the car i was thinking bout 1.5 or 2 inches what do u mean dropzone springs
Old Oct 15, 2009 | 07:35 AM
Dropzone is basically an ebay spring...a lot of people have bought them and complained about squeaking and what not...I don't think anybody has had a spring fail on them yet, but I wouldn't trust it.
You definitely won't get an 1.5 inches from SS/SC or SS/TC springs...I know SC springs are maybe .5 inch...TC might be the same or a tad bit more.
B&G, H&R, Eibach, Tenzo R are the brands you should look into (may be others I forgot to mention) and just find a used set...you'll save a ton that way.
hacadacalopolis
Oct 28, 2015 06:09 PM
cavfiredesire
Oct 3, 2015 08:02 PM
jmelton327
Wheels and Tires
Oct 2, 2015 01:54 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Delta coupe
Sep 30, 2015 08:11 AM
