Will these control arms fit?
Old Nov 8, 2011 | 02:15 PM
tpete763's Avatar
I have a 2007 cobalt LS. Will these control arms fit my car? I know there is a difference between the fe5 TC and SC control arms, but this seller says that these control arms fit all cobalts.
FRONT LEFT & RIGHT LOWER CONTROL ARM COBALT 05-10 HHR 06-11 PURSUIT 05-06 | eBay
Thank you
Old Nov 8, 2011 | 03:14 PM
C_A_D88's Avatar
They all fit
Old Nov 8, 2011 | 03:59 PM
tpete763's Avatar
Originally Posted by C_A_D88
They all fit
I thought there was a difference between the ball joint stud on the newer TC control arms? I read on here a lot that they all fit, I just want to be sure before I order them so I don't get the wrong ones.
Old Oct 31, 2012 | 10:50 AM
LS6Rally's Avatar
i know this thread is old, but the question is still the same, is the TC control arm a direct swap, or is there a difference with the ball joint stud?
Old Oct 31, 2012 | 10:59 AM
LS6Rally's Avatar
well according to Maven it isn't. sorry for not searching more before posting!
FE1 Part Numbers
Sway bar: 15822933(18mm not 19)
Bar clamps: 22608428(FE3 same)
Bar insulators: 15821022
Rear Axle: 15232753
Bar Links: 15782690(same as FE3)
Struts: 15876215/15876216(L/R, same as FE3)
Shocks: 22696400
Frt Springs: various, L/R diff.(not used by other RPOs)
Rr Springs: 22705489
Lower control arms: multiple numbers, varies by year and equipment, steel, not used by other RPOs
Knuckle: 22667248/22667249(L/R, same as all models except LNF/FE5
FE3 Part numbers:
Sway Bar: 15782964
Clamps: 22608428(same as FE1)
Insulators: 15820163
Rear Axle: 15232752(Same as FE5)
Links: 15782690(same as FE1)
Struts: 15876215/15876216(L/R, same as FE1)
Shocks: 10368516
Frt Springs: various, L/r different, (not shared wirth other RPOs)
Rr springs: 10390024(same as FE5)
Lower control arms: 15787556/15787555( L/R, aluminum, NOT the same as FE5)
Knuckle: 22667248/22667249(L/R same as all models except LNF)
FE5 part numbers
Sway bar: 15821093
Clamps: 22608428('05 only , 1bolt/1slot) 10389617(2 bolt, ALL other FE5 including LNF)
Insulators: 22700091('05 only) 15822993(06-07 only)
Rear Axle: 15232752(same as FE3)
Links: 20784688(ALL FE5 same, including LNF)
Struts: 15247245/15247246(L/R)
Shocks: 22728821
Frt Springs: 21994335(L/R same)
Rr springs: 10390024(same as FE3)
Lower control arm: 15803766/15803767( L/R, right same as LNF)
Knuckle: 22667248/22667249(same as all except LNF)
LNF/FE5 Part numbers
Sway bar: 15782696
Clamps: 10389617(same as 06-07 FE5)
Insulators: 25847760
Rear Axle: 25864579
Links: 20784688( ALL FE5 same)
Struts: 19181044/19181043(L/R)
Shocks: 25793745
Frt Springs: 25833647(L/R same)
Rr Springs: 25821162
Lower control arm: 25930725/15803767( L/R, right same on ALL FE5)
Knuckle: 25923942/25923941(L/R, unique to LNF)
I think this should be my sticky.
from this thread
https://www.cobaltss.net/forums/susp...m4-jl9-137064/
hacadacalopolis
Oct 28, 2015 06:09 PM
Delta coupe
Sep 30, 2015 08:11 AM
yellow dragon
Sep 28, 2015 09:49 PM
Coballin13
Sep 25, 2015 08:43 AM
