ZZP control arms
Browsing through their site i found the chromoly control arms that dont fit the LNF. but as far as i have read the only difference between any of the CA options is the ball joint stem. wondering if possible to use the adjustable chromoly CAs and swap the ball joint to the LNF ball joint? Ungodly noise coming from front end over any bump or divot in the road (moog sway bar links less than 2 years and 10k miles old) fairly certain its the CABs just thought i would upgrade while im there.
i would just upgrade the cabs with powell units and leave stock arms
yea their website not functioning.
hasnt in a while. have to email gloria
Go with the Powell's
Definitely go with Powell CABs.
even i prefer the powell setup
I just pressed in some moog solid rubber bushings in mine so you have the support and comfort but they won't test again. 30 bucks
| All times are GMT -4. The time now is 03:23 AM. |
