ZZP control arms
Old Feb 12, 2019 | 06:28 PM
zmschuetz's Avatar
ZZP control arms
Browsing through their site i found the chromoly control arms that dont fit the LNF. but as far as i have read the only difference between any of the CA options is the ball joint stem. wondering if possible to use the adjustable chromoly CAs and swap the ball joint to the LNF ball joint? Ungodly noise coming from front end over any bump or divot in the road (moog sway bar links less than 2 years and 10k miles old) fairly certain its the CABs just thought i would upgrade while im there.
Old Feb 12, 2019 | 07:01 PM
i would just upgrade the cabs with powell units and leave stock arms
Old Feb 12, 2019 | 07:18 PM
zmschuetz's Avatar
yea their website not functioning.
Old Feb 12, 2019 | 09:57 PM
hasnt in a while. have to email gloria
Old Feb 12, 2019 | 10:04 PM
63 Nova SS's Avatar
Go with the Powell's
Old Feb 13, 2019 | 02:40 AM
cobaltss#01's Avatar
Definitely go with Powell CABs.
Old Feb 13, 2019 | 10:49 AM
armcclure's Avatar
even i prefer the powell setup
Old Feb 13, 2019 | 11:32 AM
Powells website has never "worked"
gloria@powellraceshop.com will get you fixed up.
Old Feb 13, 2019 | 12:00 PM
C0balts5's Avatar
I just pressed in some moog solid rubber bushings in mine so you have the support and comfort but they won't test again. 30 bucks
b9k
Aug 26, 2019 08:38 PM
Miltb
Jan 27, 2019 07:33 PM
ItalianJoe1
May 19, 2016 04:20 PM
blu3_v1p3r
Oct 19, 2011 07:15 AM
Tank07
Aug 12, 2010 01:55 PM
