2.4 Supercharged log file
When I supercharged the car, we had a problem with it boosting only 2lbs. So we basically tuned the car for the injectors, and called it a day. It's pig rich for the 2lbs I'm running at the moment. I decided to try the boost bypass mod and see what is going to need to be adjusted when we figure out the problem next friday. Here is my log of the car (untuned for 7lbs).
AFR's in 9-10's lol
This was a 0-60mph run, then shutdown and stay in vac for the rest of the .5 mile ride home.
http://www.nhview.com/Personal/1-2-3untuned7psi.hpl
AFR's in 9-10's lol
yeah....i know. I put the vac line back and not boosting 7lbs now. It will give others looking into this swap an idea of what may need to be tweaked. I don't want to mess with the tuning. I'll let Fred do it while I watch and learn what he's doing.
I know, I know...I try and stay out of boost as much as possible. We didn't see any sense in tweaking things while on the dyno that charges by the hour. Sure we could have leaned it out a bit, but at the time we didn't know what was causing the low boost and wanted to stay on the safe side just in case. We know now.
Nah, not gonna post the tune.
Ouch, there are much better ways of tuning around the MAP other than unplugging it.
Your IFR calculations are going to be useless as well as the ability to run electronic throttle tests. I hope you aren't paying by the hour because basically you're rewriting all the airflow tables and it will take a while.
Plug it back in and tune the MAP out of the fueling calculations while above 1 bar.
i believe what he's saying is he's not getting any depth on any table requiring map values. This is why he's getting massive amounts of knock because our spark tables are map dependant to lower/raise spark, as well as injector offset tables to increase/decrease fuel...
a better option for a temp tune would have been to leave the 1 bar in and disable PE til you recieved the new map sensor. Since any table dealing with map vaules will take the last value in the table when it ran out of room, you could compensate for boost... but i would have set you rev limiter at 3200 and set your pe enable to 8100 along with a long talk about buying a new engine.
the car is not running this tune right now...this was to show you guys that are supercharging a 2.4 what the car is doing afterwards with relatively no tuning yet. it's running fine now!
The only table that runs out of range due to the 1 bar map should be the injector flow rate table iirc. In this case I take the same approach as an LSJ with 650cc injectors and simply make up for it in the MAF cal. Spark is still determined by final calculated cylinder airmass.
but this is a great example of multiple ways to skin the cat. lose timing control in boost, or loose an equal amount of control through out the entire range of map.
cylinder airmass is a map calculated value, without range you have no tuning in high boost levels, just static last cell values. and your going MAF-hi speed to deal with VE interruptions (which is map dependent), spark is still very much map dependent
The reason it may be looking like its a MAP controlled value is because MAP may not have been eliminated from dynamic airflow measurements and when entering boost it will cause the calculated cylinder airmass to "hang" in a cell (since dynamic airflow is relying on partial input from each sensor). This was the exact problem that celicacobalt's dyno tuner had in regards to his car going lean at a certain point. Dynamic airflow is the actual number used to calculate the amount of fuel per airmass. Its a predicted value based on map, maf, and a few other minor values. I strongly recommend disabling MAP from any air metering as once in boost you have to rely on trims to correct VE since the VE fueling cannot be logged for error even if the map will support the higher pressure (its the old HPTuners doesn't support 4 axis logging problem). You can however still use the 2.5 bar "TMAP" to calculate IFR table value and for the integrated air temperature sensor.
Not sure what you mean by "maf-hi speed", maybe high frequency? Thats just how HPT breaks down a MAF chart to make it easier to read when using higher precision.
Edit: All my info is based off of build "19" of HPT since that was the current one the last time I tuned a boosted 2.4 in July from this thread. I'm not 100% that something hasn't changed in HPT scanner since then.
its easiest to demonstrate this with a spark table histogram, a 1 bar under boost will be reading a completely different value than a 2.5bar given all other variable are the same (maf-hi speed)
maf-hi speed is the maf-only mode (no ve filtering), engine->airflow->dynamic->high rpm disable. if you log 'air calc mode' it should show hi speed.
your talking about maf-hi speed fixing the problem of "hanging" because of VE interruptions. Not sure this has anything to do with map... see next.
im not sure your disabling MAP from the calculations, your disabling VE flitering by forcing MAF-hi speed calculations. however, MAP is still used in there
witt, we all know your a pimp. respect given.
As far as the spark table hanging, this would happen anytime the MAP would be used in air metering until it was disabled from dynamic airflow calculations (with a 1 bar sensor). This was the reason celicacobalt's tuner couldnt dial in A/F or spark and why he had to send it to Hahn to be tuned; his local tuner didn't know what the dynamic airflow parameters were for or didn't know how to change them with LS2edit. The symptoms described earlier with the spark table sounded similar as well as the suggestion to swap to a 2-2.5 bar map to enable spark tuning (which I read somewhere in one of these threads, I'm starting to get them mixed up).
I have the original logs from ppazz's turbo somewhere on my laptop. When I find them, I'll post them up, maybe can do a little comparison on boosted 2.4s.
