2.4L Info needed -- Someone who has a stock tune should read.
Ok, so I got my thermostat installed...but its still running a little hot.
Ive read somewhere that the fans come on (only at like 5%) at a specific heat, then 100% at another.
@ 200+ *F the fans are NOT on.
Can anyone tell me what the stock ecm says they should be on at?
I know the fans come on @ 100% at around 220.
I want to know if the fans are supposed to be on (even a little) at lower temps.
I read on here that they were on @ 5% at lower temps.
Stock slope is: (for a kappa in EFILIVE)
Fan % vs ECT °C
y = 3.125x - 278.12
Fan % vs ECT °F
y = 1.736x - 333.67
Chart data:
Fan% Deg °C
89.0 0.00
91.0 6.25
93.0 12.50
95.0 18.75
97.0 25.00
99.0 31.25
101.0 37.50
103.0 43.75
105.0 50.00
107.0 56.25
109.0 62.50
111.0 68.75
113.0 75.00
115.0 81.25
117.0 87.50
119.0 93.75
121.0 99.99
All of the other values are the same except run time of 78 vs 780 seconds. I have a beta version of EFILive so I suspect mine is wrong.
Fan control is needed to keep the engine temperature in the most efficient range.
With a Turbo in a FWD application you would need a much more aggressive slope for the fans along with a cooler thermostat. Don't also be surprised if you end up needing a larger radiator too - especially if it's an automatic.
Fan % vs ECT °C
y = 3.125x - 278.12
Fan % vs ECT °F
y = 1.736x - 333.67
Chart data:
Fan% Deg °C
89.0 0.00
91.0 6.25
93.0 12.50
95.0 18.75
97.0 25.00
99.0 31.25
101.0 37.50
103.0 43.75
105.0 50.00
107.0 56.25
109.0 62.50
111.0 68.75
113.0 75.00
115.0 81.25
117.0 87.50
119.0 93.75
121.0 99.99
Turbo Johnny
Feb 21, 2019 09:41 AM
