2-step WARNING!
To not bog you need to have the cutoff set with respect to your gearing, with a few hundred RPM error.
ie) LSJ, F35 tranny, 7000RPM redline - set to ~5100RPM +/- ~100RPM
Too low, and the engine can't lower the RPM fast enough, hence your engine 'dying'.
Change what I have painted the arrow to and it will change your resume point.
Edit: After trying my hardest on my way home from work to duplicate the problem of hitting the P/N rev limiter while moving I think its safe to say this problem is tuner error.
You guys having this problem are either setting the hysteresis way too wide, using an in gear modifier less than 2 for some reason, or are running your p/n limiter at less than half of your in gear limiter. Any of these errors will cause you to bounce off the p/n limiter.
When correctly tuned, this mod works just fine.
Your p/n limiter can go as low as half of your in gear limiter and you'll never touch the p/n while the car is in motion.
Are you juicing your stang?
Yep, I had it set to less than half the In Gear RPM. Because I don't launch at 4500rpms. If you want to launch at 4500-5100 rpms then I'm sure it works fine. I don't think most people would enjoy that, and using it as a 2-step for most people is out of the question in ill advised. If you have the capability of launching it safely from those RPMs then you are a step ahead of most people.
lol, well yeah, I'm pretty sure that helped the motor go boom.
I try and never hit my limiter..... it almost makes scary explosion sounds and large ***** of fire come out of my car occasionally
Dan said the HHR SS launches at 5200rpm on the stock two step.
im not sure why someone wants a 2 step on roots blower anyways. you can go from 0-15 in the blink of an eye.
::shrugs::
ya ya i got 2 step, car go pop pop pop pop vvvvrrrrrrrroooooooommmmmmmmm
i got nuthin
I don't use one but there are a couple turbo cars around here that do, one with a fairly large sized one at that.
