afr w 2.6?
Old Jun 21, 2009 | 10:19 PM
thc's Avatar
thc
afr w 2.6?
so i recently purchased a 2.6 pulli and would like to run it on wensday when i go to the
track but i dont have a 2.6 tune for it yet. waiting for my tuner to send it to me still. i had
the pulli on the car for about 10 minutes just to see the difference in afr and with my 110
race gas tune the afr was 12.5-6 on the 2.6 (tuned w a 2.8 w a 12.0 afr). so my question
is would it be ok to run w this lean of afr or should i just wait for the tune? ill only run the
pulli when i get to the track and switch off when im done.
heres my mods : forged and coated pistons .20 over,clevitte main and rod bearings,arp headstuds,ported head,60#inj,aem wideband, injen intake, mid-length header, 3"catless downpipe, 3" catback. quafe atb differential, clutch masters stage 1 clutch,dualpass endplate w fmhe, aem boost guage, hptuners suite, b&g coilovers, ottp stg 2 rotated trans mounts.
Old Jun 21, 2009 | 10:21 PM
ColeJJones's Avatar
Bannned
your going to blow your ****** engine!@
Old Jun 21, 2009 | 10:24 PM
EXsoccer1921's Avatar
2.6pulley>2.6pulli
Old Jun 21, 2009 | 10:25 PM
95cam86roc's Avatar
x2....
Old Jun 21, 2009 | 10:26 PM
thc's Avatar
thc
ya figured that much but had to ask
Old Jun 21, 2009 | 10:31 PM
BLAZIN07SS's Avatar
I'm too JDM for you
eh, its not gonna blow up with one pass down the track but better be safe than sorry. i have seen a ss/sc hold 13.5 AFR w/ 17* of timing on 20psi from a TVS. lol
Old Jun 21, 2009 | 10:38 PM
thc's Avatar
thc
ill just wait for the other tune. like u say better safe than sorry. sucks having hptuners and not having a clue how to tune. lol
Old Jun 21, 2009 | 10:46 PM
383_Stroker's Avatar
Do you feel lucky?.. lol
Old Jun 21, 2009 | 10:53 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you have a PM about fixing that AFR
Old Jun 21, 2009 | 11:09 PM
thc's Avatar
thc
awesome! thanks
Old Jun 25, 2009 | 09:35 PM
thc's Avatar
thc
so my aem eugo guage reads 11.8 (what im commanding with pump gas) and hptuners is logging 12.1. what one should i believe and how can i make them read the same?
Old Jun 25, 2009 | 09:45 PM
NVMYCOBALTSS's Avatar
If I am not mistaken, the AEM gauge would be more accurate. But I will let the tuners answer that one. subscribed.
Old Jun 25, 2009 | 11:11 PM
Rippin07's Avatar
you sometimes have to add a correction factor to the HPT for the scanner to read identical to the gauge. Believe the gauge as it is more accurate for you right now.
Old Jun 26, 2009 | 12:44 AM
Area47's Avatar
Rent me! per hour
no it's not.
Old Jun 30, 2009 | 11:53 AM
thc's Avatar
thc
where in the scanner do i go to add the correction factor ?
Old Jun 30, 2009 | 12:04 PM
Admiral Jedi's Avatar
This should help with the wideband question: http://www.hptuners.com/forum/showthread.php?t=5059
If you're using race gas, you can run it leaner, but I would give it some cool down time after each pass because leaner = higher exhaust gas temperatures (egt's).
Old Jun 30, 2009 | 12:23 PM
thc's Avatar
thc
i am running race gas. vp110. . i give the car plenty of cool down time in between runs. the last time i was at the track my iat2s were 140 before i even left the line so
gotta give it cool down time.
Old Sep 19, 2009 | 01:34 AM
SuperSport4's Avatar
its not gonna blow.... specially using race gas.... i run 12.2 - 12.5 on meth an no knock....
Old Sep 19, 2009 | 01:38 AM
Jn2's Avatar
Jn2
mne ran at 12.5WOT when i was untuned for my 3.0" pulley, had the stock 3.35" pulley on there, didnt blow after a few runs, although i never really got on it for more than 10 seconds :p
Old Sep 20, 2009 | 09:33 PM
thc's Avatar
thc
well i diddnt put the 2.6 back on until a couple days ago. it was just to hot out to run it before.
so now i have the 2.6 on and im trying to get it dialed in with my pump gas tune.
first thing i did was make sure everything was reading good with the 2.8 tune(dd tune). it was running a little lean due to the weather changing. was commamding 11.8 was reading 12.2 . so i changed my commanded afr to 11.4 to compensate for the weather.
so now its back to 11.8 sometimes 11.7.
i go home swap pullies and take it back out. do a couple of pulls by the lake and afr is 12.1/12.2. so i took 12.2/11.4 =x and changed the maf airflow vs output freq from 6000hz up multiplying it by x. now its read ing 11.6 11.7 with a little kr.
heres the log
so since it was a little rich after the adjustment i copied the 2.8 maf back and re adjusted using 12.0/11.4=x
heres the log
so now afr is right where i want it 11.7 11.8. still some kr. and i noticed that my ltft was at -2.3 this time.
what would make the ltft change? i diddnt change anything but the maf adjustment. kinda confused.
any ides what the kr could be from?
Old Sep 21, 2009 | 12:27 PM
Hot Air!
Old Sep 21, 2009 | 12:52 PM
thc's Avatar
thc
Originally Posted by 383_Stroker
Hot Air!
i was kinda thinking that too. heats been my biggest battle with this car this summer.
hopefully the opt b tank im getting this week helps.
Old Sep 21, 2009 | 01:15 PM
Actually the IAT2s aren't that high in the second pull when it hits the knock.. what kind of timing are you commanding?
Old Sep 21, 2009 | 01:22 PM
thc's Avatar
thc
commanding 18* of timing
Old Sep 21, 2009 | 05:09 PM
well i use to see well over 151 with my 2.6.... i live in miami... but ur timing is on the floor... 15 and 11* of timing... i do not recommend the 2.6 without meth..... u can make just as much power with a 2.8 and a good tune.... u might have a little less tq but u can run more consistant.... my $.02
