Auto LE5 help
Auto LE5 help
Can someone please look over this tune and give me a little insight on what might be a problem. I am tuning an 07 LE5 with an auto tranny; I have the engine part running find. But the tranny tuning is new too me. Now what is happening is when he is going WOT the Tranny is not shifting in the next gear it is sitting the bouncing off of the rev limiter and only shifts when he lets up for a slight second. Under normal driving conditions the tranny is shifting tights and faster but I am just having problems with the performance settings. So any insight great
Heres a link to the tune Click here
Just like Witt said. Lower the MPH for the shift.
Alternatively you could raise the rev limiter if it would still be in a safe range.
Basically it won't shift until it hits that MPH, but if it hits the rev limiter before that mph it will just bounce and hold gear. When you lift off the WOT it reverts back to the Partthrottle shifting which SHOULD be set at a much lower MPH.
BTW> Is this a tune that you created? I put a bug in my LE5 tune on purpose to make sure the car would not shift out of 1st gear when WOT so that anyone else using my tunes would have to know what they were doing to make the tune work on a car. (a cheap way to see where my tunes went) I had the MPH set about 2mph too high in 1st gear for that reason. Let me know if you got the tune from someone else, because I would be the first to tell you what other bugs I hid in there that you will want to change.
Terry> I'm taking a guess that he may have got my tune, which you also have.
Last edited by Psykostevo; Jan 24, 2008 at 03:07 PM. Reason: Automerged Doublepost
So it was a bug that had DOC stumped and ultimatly had him re-flash my 07 ECU as an 06 ECU?!?!?!? I couold give you such a smack in the head!
but I have since collected a few more tunes then just yours.
But yeah, scale back the MPH on the 1-2 shift point and you are golden. (Then multiply the injector flow rate by 0.94, and you've got it) That's only for the Stage 2 tune I did with the injectors from the SC and the harnesses you got me. The other base SS tunes did not have the shift points set so high, and were more of just a firm push instead of a kick in your pants.
Terry if you could, please email me a copy of a working auto 2.4 tune please. This is becoming a promblem because the guy lives in Daytona and I am in orlando.
Email is REDFOCZ@hotmail.com
Steve I beleive this is your tune, but I got it from Sean (Illamaitics). Not all of the settings are the same, It has my engine tune with bits and peices of other tranny tunes that have dome my way. I have played with both the MPH for the shift and the RPM, and have alted them I know for a fact that the MPH is lower then the RPM rev limiter.
BTW I gave up on tuning mine ause of all the bull **** I went thru. My poor car was flashed more the someone on a nude beach!
I can spot my tune from a mile away.
Last edited by Psykostevo; Jan 24, 2008 at 03:36 PM. Reason: Automerged Doublepost
crazy.....told him he probably set the engine rpm too low. I had that tune set for a 7300 rpm limiter because the cars were equipped with bigger fuel injectors. He should have scaled back the shift mph. Trannies can be tricky to tune. Could just be a lack of experience and might not know what to do. But I called him yesterday and we talked about it.
Anyways Ill shoot that out to you later on this evening when I get out of work.
Hmm steve I will email you a copy of the last tune that I placed on his car if you could look it over that would be great, I tried doing what we talked about on the phone and it was just sitting there bouncing off of the rev limiter, so I have no clue why I have the enfing RPM rev limiter set highter then the tranny like you said to do and also set the MPH for the shifts lower aswell. Auto trannys FTL
Ill stick with a 5 speed thank you
Ok so Steve do you want to try to do my car again? I have a professional shop who wants to try it but your tune was so good even messed up that I want to try it again. Do I still need the 2.0 injectors? I still have them if so or can you tune the car for the stock 2.4 injectors?
I am glad to help you Terry. I want to see it work. I think YOUR only problem aside from the DOc crap was my mistake with the injector flow rate which had your car tripping the TC/ABS bologna.
Its funny because if I was there in person I could have all your guys problems fixed in 10-15 minutes realistically. I can work magic on these cars that you have to see to believe.
Last edited by Psykostevo; Jan 25, 2008 at 06:02 PM. Reason: Automerged Doublepost
Explain this...how did IFR make the car throw TC/ABS lights...and what did u do to fix this...Ive never heard of this...and really aint sure how theyd be related.
lol ill be sooo happy to be dippin in the low 15's hahaha now that i got that pwer thing for your laptop we dont have to worry bout it dieing LOL.. cant wait o yea and thx every1 for the imput
o yea can i get a link to that video? i would love to see it
Last edited by xx07cobaltss24xx; Jan 25, 2008 at 07:13 PM. Reason: Automerged Doublepost
That's what Jackalope said was going on. I have NEVER personally seen it. More than likely all those problems had something to do with DOC using an incorrect operating system, but as Jackalope explained it. Everytime his car thru the lean code Traction Control and ABS would disable, and when the light went away they would re-engage.
The lean trim code is from incorrect airflow or fuel tuning. It probably wasn't the only one thrown at the time. Certain DTCs will disable all torque management and command full line pressure shifts from the auto tranny. Its a safety feature depending on the DTC communicated from the ECM to the TCM. A shop manual will state which DTCs will do this. Ones such as slow o2 switching and MAP-MAF correlation codes certainly will do this and probably were triggered with incorrect airflow or fuel tuning.
I wouldn't blame Doc so quickly. That situation would be completely in the tune. The OS's are swappable as the hardware itself never recieved a revision between the 2 years.
figured id post..cuz my name was up here...umm steve did send me a tune back in the day...i wrote my tune with 06blackg85ss. we looked at his tune to get some knowledge about tuning. but guys seriously..on this auto trans..a tranny cooler is a must. when i logged it back in the day..a lot of slippage and increase of temp was bad...with the cooler addition...increase in temp is minimal and slippage is not there anymore...i just sent witt my current tune and log..but my car runs strong...tranny tune is tight.
the lean code is from if the ltft goes above 13%..if it does boom cel, this also caused the t/c light to display on startup...figured that one out...havent seen that code/ t/c light in a long time..hahaha
ok this is weird with my tranny tune when REDFOCZ is in the car tuning it, it runs great then once i put a couple miles on it (20+ or so, the longer i drive worse it gets) it will stop wanting to do shift under WOT... I just dont get it and we are only logging it revving to 6800 even though all other settings are set much higher... right now it shifts in "L" under WOT 1st to 2nd but then when i shift it in to "I" it doest shift just hits rev limiter and stops... o yea its the same for "D" doest shift 1st to 2nd or 2nd to 3rd under WOT i have to lift for a second for it shift and its kind of annoying...*sigh*...
