Cobalt SS/SC 2007
Hello,
I recently purchased hptuners and I am using it on my almost stock cobalt so that I may learn how to use it properly before installing a lot of parts. While logging I noticed a few things which I have questions about. 1) I noticed that that my tps only hit 88% under wot. I did several wot runs to see if it was just me, but they all had the same result. 2)I did the KPA convert to Boost in PSI and when I do my runs I notice that my analog boost gauge reads slightly higher than the HPtuners Boost Gauge. Is there a reason for this? 3)I hear a lot about turning off torque management but when I look in HPtuners for for a related subject, I see there are several torque management options with no obvious on/off switches. Can you direct me to what I am looking for? My only mod is an INJEN CAI http://www.mediafire.com/?xz0yyzz1ljl |
1)http://www.hptuners.com/forum/showthread.php?t=10993
2)Stock boost gauge in car is not exactly accurate 3)You do not "need" TQ management. There will not be an "on/off" you must set the cells to "0". |
First off thank you for the quick reply.
You said "set the cells to 0" what cells are you referring too? engine torque tab vs iat? vs ac preassure? general tab or under spark reduction where it says torque reduction? |
Sorry that was vague I meant 0 everything out under the TRANS section.
Under the AC pressure and IAT cells I left alone. Under the ETC limits and spark retard mine is 0. Max brake torque managmentis set to 6042. I have not had problems when it was changed. I guess wait to see if someone objects with me. I have not been tuning as long as most.. |
What did that tuner run you?
$649.00 (pro edition) Then you need a wideband O2 sensor unless you don't plan on adjusting AFR or don't care to do it with a Narrow Band (which is kinda difficult)
As for the Transmission section. My transmission section is completely blank when I open up the VCM scanned file. Do I need to plug into the car to be able to view and change anything under the Transmission tab? |
its in the editor not scanner
I am talking about the editor. The transmission tab is just blank
if i got Engine tab>torque managementl>general is see the following ETC Lmiits>ECT TPS Maximum and Spark Retard>Vs. Torque Reduction but under the Transmission tab there is nothing |
You are in a tune file right?
Under Trans-> I have Auto Shift Speed, Shift Properties, General Pressure, Auto TCC, Manual C.A.G.S, and last Torque Management. |
That is where i looked the first time and I see those tabs, but i do not see anything inside of them.
I emailed HPTuners about it and they said this.
"There is no tcm code in the 07 cobalts, gm never put it in there since they use a manual transmission(ie they finally got smart about it)." So I guess I am unable to edit anything in the transmission tab |
Originally Posted by wesphily
(Post 4868218)
whats the difference in the pro edition and the 500 dollar one??
Originally Posted by GM COBALT SC SS
(Post 4915560)
what cobalt do you drive and where are you located
