Config file help
Config file help
I'v been logging a lot lately, and for the most part my config file is setup nicely for me. One thing that's really been bugging me though is that the MAP I'm just about positive isn't recording correctly. It read about 25PSI when I was stock, and with the 2.8 it reads up to about 32 PSI.
here's my config http://www.akronracing.com/images/Jason_SS_SC.cfg
(Sorry about the big pics)
Both of these are with all the mods listed in my sig.
PSI
KPA
PSI
KPA
http://www.hptuners.com/help/tips_an...p_to_boost.htm
The reading you see in the table display is absolute pressure.
Here's some info on map sensors and how they work http://en.wikipedia.org/wiki/MAP_sensor
And some more http://www.hptuners.com/forum/showthread.php?t=9255
Thanks for the info, that's simple enough I can't believe I didn't figure it out. I'm having a problem fixing this though. When I try to add a custom PID I put all the info in, but when I try to use the PID it's not in my list of User Defined PID's. If I try re-create it the PID is already created. Is there something I'm missing here?
your iat is normal. IAT 1 will be close to ambient if not a tad higher since its measured near the air filter. IAT2 will be in the low to mid 100s as it is measured inside the manifold.
Check your AIT1 & 2 configurations.
Pierre
