Help Please
Old Apr 2, 2008 | 04:58 PM
crazysteve's Avatar
Help Please
So I finally got the 60#'s in and a 2.7" pulley......for some reason in 2nd gear it goes way lean from about 3700-6400 (13.2-1) but in all other gears it is perfectly fine.....any one have any ideas.....was running basically a GM stg 2 before with no problems.
Old Apr 2, 2008 | 05:08 PM
Raven SS's Avatar
because u cant run a stg2 tune with 60s and a 2.7
Old Apr 2, 2008 | 05:18 PM
crazysteve's Avatar
I have retuned the injectors per the sticky.....idles fine and runs great when you are not in 2nd
it runs good in 2nd but way to lean
Old Apr 3, 2008 | 08:51 AM
crazysteve's Avatar
No ideas....only goes lean at WOT, partial throttle is good.
Old Apr 3, 2008 | 07:51 PM
Pickles's Avatar
Sounds like you need to tune your maf.
Old Apr 3, 2008 | 07:52 PM
silentd's Avatar
u installed 60s anda 2.7 on the stg 2 tune....... um theres ur problem
Old Apr 4, 2008 | 03:48 PM
crazysteve's Avatar
I have hp tuners...been working on the tune...did not just change the parts. I know that would not work.
