HPTuners Question ...
Old Aug 25, 2007 | 07:50 PM
Jmc007's Avatar
Engine, Airflow, General Airflow, Main VE (Primary) : The software states : "It is also used to provide transient condition correction to the main VCM airmass calculation". Min =0, Max = 4096.
-So first of all, what are the units of those values ?
-Second, can these value affect PE mode ?
-Are we required to fine tune them ?
Thanks !
Old Aug 25, 2007 | 07:55 PM
foff667's Avatar
-milligrams I believe
-if your in SD mode yes they can I don't believe they affect pe mode while you have the maf enabled though.
-required? no.
Old Aug 25, 2007 | 09:26 PM
Jmc007's Avatar
What is SD mode ?
Old Aug 25, 2007 | 09:34 PM
Sunburst_SS's Avatar
SD = speed density, which is your VE table tuning I beleive
Old Aug 25, 2007 | 11:47 PM
bigworm's Avatar
the units of those values are labeled on the side of the graph, "mass air pressure in kPa"
Yes, they do, as they are a baseline for your PE. Your PE tables are multipliers
Yes and no, you can run SD mode and rely completely on them, the stock method which is a combination of VE/MAF, or you can run pure MAF/MAP and ignore the VE
look around on hptuner's forums for open loop and closed loop methods used... that has to do alot with what your looking at..
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
Adecker
Oct 20, 2015 09:46 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
