Life after 215kpa....
So the stock MAP sensor maxes out around 215kpa ~ 16psi so what is controling the fueling process above 215kpa??? The VE table is maxed out at 215kpa so its it just the MAF HZ that you tune to control fuel???
holy shit i have no clue what you are saying. but im interested to learn or is this canadian psi??
kappa.. canadian psi
he is talking about fuel maps for boosting over 16 psi |
are you running SD all the time ie no maf?
Originally Posted by Acidangel_5.0
(Post 840390)
ni am not but if i was what would happen???? it would just use the value in the 215kpa column in the VE table even though its over 215kpa right?????
and when not in SD mode it would use the value in the 215kpa column and rely on the MAF for all other fueling calculations???? |
good question...haven't gotten that far yet.
listening. Nate |
im sure foff667 will have a answer for us.........he seems to be full of usefull knowledge
MAF is the primary means of air metering. Your MAP sensor is 2.5 bar, your table is 2 bar. When you go out of range on the VE table, it just uses the last known good value which would be the 215kpa column.
Originally Posted by Kennyspec
(Post 842137)
I think that some people have experimented with an LT1 MAF with some success. This will allow you to not go above the HZ limits of the MAF table.
I think the sensor it good to over that, but the tables in the stock PCM don't read it... Goes by PE table after that.
(Post 842137)
and when not in SD mode it would use the value in the 215kpa column and rely on the MAF for all other fueling calculations???? So the life after 215 has very little bearing in the overall fueling for the most part unless your running SD all the time. When the maf is in play you can use the maf/pe tables to do most of your fueling adjustments. |
Originally Posted by Jim@Tagracecraft
(Post 843190)
Don't waste your time on Sd tuning.
Look to adapt a Maff from a Ls1 based truck They are good to about 60lbs of air flow..That would be a good idea. |
what about all the guys running a 2.9" pulley? Isn't that over 16psi?
Originally Posted by Witt
(Post 843231)
You'll have to do some SD tuning if you plug 60lb injectors in there, or you'll be in limp mode pretty quick. But running SD is mainly a waste of time because of the 2 bar limit on the software.
Originally Posted by SilverStreak
(Post 843240)
Originally Posted by 06blackg85ss
(Post 843241)
I"m running 60lb injectors and the car runs fine... just added @3% to the Ve table and no problems..
i thought that you "set" the PE table to what AF ratio you want. ex. 14.7/12.0= 1.225
so if i want a 12.0 AF ratio all the way up to 7000rpm i would just set all the values in the PE table to 1.225??? How do i use the PE table to adjust fuel when my MAP is maxed at 215kpa?? wouldnt i just log the % error in the MAF histogram comapring my commanded afr to actual???? and use the MAF to control my AF ratio and not worry that the map is maxed out at 215??? |
(Post 846891)
so if i want a 12.0 AF ratio all the way up to 7000rpm i would just set all the values in the PE table to 1.225??? How do i use the PE table to adjust fuel when my MAP is maxed at 215kpa?? wouldnt i just log the % error in the MAF histogram comapring my commanded afr to actual???? and use the MAF to control my AF ratio and not worry that the map is maxed out at 215??? 2) The PE table is based on RPM, not map, the 215 kpa value doesn't affect it. 3) Yes, also correct. |
