maximum safe spark dwell
Old Mar 29, 2007 | 08:14 PM
distillion's Avatar
well my surging issue has been found, we upped the spark dwell and the surging in second is almost gone, ive lurked around the hpt forums and some people say 6ms is the max but this is for fbodys i belive. My question, is it safe to hit say 5.3-5.5 ms past 6000 rpm cuz thats where im getting the surging, between 6000 and 7000?
Right now the car is a hair past 5ms and it looks like it needs to be upped just a tad more for a clean redline, thoughts are welcome and yes i searched but no real concrete reason was given on what happens to the coil packs and what the dwell was set at when failure occured.
thanks again.
Old Mar 29, 2007 | 08:26 PM
Toronto SS's Avatar
interesting... I too would like to learn more about this.
Old Mar 29, 2007 | 08:52 PM
Mase's Avatar
Mike I think it was 5ms we were around not 5000ms, that's 5 seconds
I'll check the RL forum
WOP is needed for this one
Old Mar 29, 2007 | 08:55 PM
Doc's Avatar
Doc
I believe Rob posted something about this....I can't remember what he said either. Time to search
Originally Posted by FAST06SS
If you have HPTuners,
Reduce your boost below 5K in 1st gear, it will allow a MUCH quicker 60', (Thanks Daren for the backup)
Spark Dwell,
Highlight entire table and extrapolate from corner to corner. Don't go over 5ms above 6K
Trust me on that one
Add a second heat exchanger in front of the condensor and run in series with the stock one.
30 to 120mph only gained 39 degrees on IAT2 versus 50-60deg stock set-up.
Enough for now
Old Mar 29, 2007 | 09:14 PM
Mase's Avatar
I think it's "interpolate" as there is no extrapolate that I see
Ok here is the stock dwell (or GMS2, I don't remember which one this is)
and this is with interpolation:
I don't know about his one as it looks too easy. There is no way a nice even graph can give you the best result, maybe in theory but never in practical.
Mike I say we increase after 6K until it's good.
Old Mar 29, 2007 | 09:21 PM
Doc's Avatar
Doc
true....
Old Mar 29, 2007 | 09:44 PM
distillion's Avatar
Mike I say we increase after 6K until it's good.[/QUOTE]
OOPSY ya too many numbers i get confused, still learning LOL
yer the boss
i edited my original post, makes a tad more sense now lol
Last edited by distillion; Mar 29, 2007 at 09:44 PM. Reason: Automerged Doublepost
Old Mar 29, 2007 | 10:31 PM
BlackSS/SC's Avatar
Mine is set up a little higher just in one little square spot. I'd like to hear more about this too. Like what the side effects are and what changing the numbers actually translates to.
Old Mar 29, 2007 | 11:39 PM
Sales@rebelautoworxs's Avatar
Increase the dwell time to 6ms It will be fine. The amount of time spent there will not affect the coils negativley.
The Ls1 truck coils have been proven to 1400hp.
I'm sure Gm did a good job on the LSJ coils.
Old Mar 30, 2007 | 12:04 AM
distillion's Avatar
hmm interesting, thanks buddie!!
what should the gap be for the plugs?
Old Mar 30, 2007 | 09:41 AM
Grap them at .32-35 With a 7 heat range plug of your choice.Stay away from iridium plugs. Let me know how this worxs for you.
Old Mar 30, 2007 | 10:30 AM
BlackSS/SC's Avatar
So what does the spark dwell actually do?
Old Mar 30, 2007 | 10:44 AM
distillion's Avatar
right now they are at .32 with ngkbkr7es, as mase upped the numbers car got better, needs a bit more to be perfect, its wierd cuz the only gears it does this in are 2nd and 3rd, i can usualy get on her in second but its almost imposible to max 3rd during the day, so hopefully when the redline is smoothed out in 2nd, 3rd will be good aswell.
thanks again.
Old Mar 30, 2007 | 10:52 AM
If the dwell time is too short, the current in coil doesn't have enough time to charge fully.<and you want the most current you can get>
The longer the dwell the more time it has to charge.What your expierencing is most liklely some spark blow out.
2-3rd gears have more load on the motor.
Old Mar 30, 2007 | 11:05 AM
distillion's Avatar
makes sense.
Old Mar 30, 2007 | 11:12 AM
BlackSS/SC's Avatar
So this can negatively affect the coils life?
Old Mar 30, 2007 | 11:34 AM
It may shorten the coils life, it will introduce more heat into the coil. I haven't heard of any coils failing on any ls1's or lsj's that i know of.
Old Mar 30, 2007 | 11:39 AM
BlackSS/SC's Avatar
So they say don't go over a certain MS and don't go past a certain RPM? Do you know what the rules to this are? I may try it
distillion's Avatar
so by increasing it to 6ms, thats the safe zone per say?
Old Mar 30, 2007 | 01:03 PM
BlackSS/SC's Avatar
Here's the link to Rob's older thread about this. https://www.cobaltss.net/forums/show...ht=spark+dwell
Old Mar 30, 2007 | 01:39 PM
Small Changes are best and see what the Car likes. You want to get away with as lttle as you can .
Old Mar 30, 2007 | 02:13 PM
distillion's Avatar
so in my case if the car pulls good using 6ms, i should be ok correct?
Old Mar 30, 2007 | 03:07 PM
BlackSS/SC's Avatar
Here's another link from the HP Tuners site about spark dwell http://www.hptuners.com/FORUM/showth...ht=spark+dwell
Old Mar 30, 2007 | 03:24 PM
ItalianJoe1's Avatar
Very interesting stuff here. I gotta get this stuff down so I can get my own HPT suite.
Old Mar 30, 2007 | 08:14 PM
BlackSS/SC's Avatar
bump for the evening
