New tuning program for LSJ's. Need some help though
Almost finished with my DIY tuning program port for the LSJ's. It will be like the programs Evo's and Subarus use. You will still need a tuning cable(like the Tactrix), or modify your tune with my program and upload it with HP Tuners. It will have about 800 parameters unlocked. HP Tuners only has about 100. Tons of stuff missing that is really needed in HP Tuners.
What I need now to make sure everything is working right is some .BIN files of stock tunes. Need 04-07 LSJ bins. I only have my OS bin so far, and I think there is about 12-14 out there. So, if you have a raw bin file of your tune, please contact me. It does not have to be stock, but I would prefer it that way. I do not need .HPT files. I need a raw bin file to finish mapping them out for the other years. |
In for results.
I am so intrigued especially with my tuning woes. |
That might be a tough one for us to get for you op. Most of us have no way of pulling the bin file from the pcm unfortunately. Like I for example have a ton of vehicle files, just no way of pulling the bin out of them or directly from the pcm. Is there a pretty clear cut way of doing this?
Originally Posted by 09CobaltSS1
(Post 7202181)
I have tactrix cables, elm cables and a couple other that I honestly forget the names of.. lol
What program would I need and how can I pull the bin using the tactrix cable? |
(Post 7202192)
Where can I get a tactrix cable?
Where can I get your program? I have about 50 local area cobalts and ions that I can pull files from. PM me with a walkthrough and Ill start pulling files and sending them to you |
This sounds interesting. LSJ only? Le5? heh
Interesting
:d
in for LE5 :)
In for l61? Lol
i am doing LSJ only first. The reason being the P12 computer is hardly even supported by HP Tuners or EFI Live. There are a ton of tables that are not mapped out at all. They are there in the PCM.
The LE5, since it uses the E67 ECM, is 100% unlocked for anything you would ever need to tune it. Not sure what ECM the 2.2 uses.......is it the E38? Now to give you an idea of what it takes just to do ONE OSID. It took a good 500 hours just for my current OS. Combine that with the 13 other OSID's out there for the LSJ, and you can see how much time it takes. Again, we do not have a current DIY P12 option unlocked to its full potential. The LE5 world already does. If someone wants to help out and map out the LE5 definition files, by all means go for it, and I will provide you the tools to do it. |
subscribed.
does that mean we will be able to have ecm controlled window switches or switched fueling tables for things such as nitrous? |
Open port 2.0?
So the le5 is good to go with hpt?
(Post 7202558)
Ok I got all the bin files I need now.....thanks!
Now to spend an asinine amount of time making this work. So far the options are porting Tiny Tuner to work with the LSJ, writing a definition file for Tunerpro, porting it to the RomRaider software, or finishing what I have came up with from scratch. But honestly, Tiny Tuner is a LOT more user friendly and I am leaning more towards that. This also hinges on permission from the guy who wrote it, but we have been emailing back and forth already. The flashing part will be handled by HP Tuners, EFI Live, or a stand alone Tactrix Ecuflash variant. This is still a few months out from being finished, so bear with me here.... |
If you need anything else let us know. I have an OP2.0.
click
If you need any more files or anything LSJ/Tactrix related post up. I have a tactrix cable and access to a bunch of LSJ's from 04-07.
Originally Posted by lwrs10
(Post 7203060)
need a bit more help here. To use the Tactrix Openport 2.0 cable, a program would have to be written. There is another option called AVT that is about the same price, and there is a program already out there that works with the AVT cable for flashing. In fact, the black box that Trifecta uses is built by AVT.
If anyone is familiar with how to write API based programs, please contact me. I am not a programmer. |
PM'd you. Ignore the first part, I didn't read that you have all the files :lol:
There's no way to just add a definition file for openECU?
On their website it says gm support coming soon... I'm still new to openECU, have they been saying "coming soon" for a while? |
