PCM LOCKED!!!??? Trifecta tune
I have a tune on there by Trifecta im switching to Hp tune an im trying to reload the stock file an it wont connect to the vehicle, i also tried letting the dealer reflash it with their stuff an they cant connect to it also, what do you guys think is the problem, could it be the black box? thanks for yall's help
The tune isn't locked, but HPT isn't compatible with our software. You'll have to flash back to stock before tuning with HPT. Be sure that you have the latest version of EZ Flash installed as well. Here is the link to the update EZ Flash - WOT-Tuning.com
Typically we can write entire over the Trifecta with HPT but it didnt work for this ECU. I have also been able to pull the tune and save it (even though I cant see anything) but it didnt even connect thru HPT. There is an issue if the dealer cant even use Tech2 to go back to stock.
I think im in the same boat as you.
I heard that Vince locks his tunes but according to the Trifecta website they dont and its an option by the customer, so technically it shouldnt be locked unless you say you want it locked. I really need my tune adjusted as im throwing multiple codes and i need a few disabled and theres only one trifecta guy around.
I might get a new PCM but will have to get it relearned iirc, but i will have a tuned trifecta pcm and tuned hpt pcm if i decided to do that.
