Psykotune VS Trifecta Infiniboost
Up for comparison in an 08 Cobalt SS that was tuned by me at 22psi. Then that same car back at the dyno with Trifecta's Infiniboost running 27-30psi. Surprised to see that the 27+psi made significantly less HP at the wheels than the 22psi tune that I wrote.
Mods to car are Hahn Intake, Hahn Charge pipes, Hahn Intercooler, and Hahn Downpipe.
Was it a stock turbo car? Might be because infiniboost is designed for larger turbo's. Also if this is the person I am thinking of they have not installed their datalogged tweaked map. Also your numbers are extremely low for both, you have them in STD corrected with 0 smoothing. I made more WHP with my superchips tune.
(Before I moved here I worked at a dyno shop too)
Also post up a sheet with SAE numbers and smoothing on atleast 3, people will see this car isn't exactly taking to a tune well.
Oh, why thank you captain obvious. Just stating he is not the GOD of tuning he thinks he is...
I've gone to the same dyno each of my 4-5 dyno runs...
But I'm glad you told me that I would have gone my whole life thinking all dyno's were equal!
To where I am now... 353whp and 387wtq
Nah, he comes in here with a I'm better than everyone attitude. It gets old... SORRY
People on here have made much more power, ON A WIDE VARIETY of different dyno's.
Plus I have seen what "HIS" tunes have done on cars... it's nothing special... most of them are down right horrible!
ive used the same dyno that steve uses and its a bit of a heart break dyno. ive rode in the car the car that has the infiniboost thought it pulled good was surprised how low the numbers were though. isnt there a guy on here claimin 330whp with this tune?
the only number that should matter are 1/4 mile times
did you get a stock dyno run to compare with your tuned pulls? i find its really hard to believe your putting down those numbers im mean ZZP dosnt even have those number with full bolt ons and ported head.
Yeah, stock was 258whp and 261wtq with 1800 miles on the clock... They aren't inflated believe me! There are plenty I have tuned, and using a similar tune putting down VERY similar numbers from NC, to KC, to FL.
i only know of 2 people claiming those numbers on stock turbo.
i just have a hard time believing that you are make 40whp more than me and i have more supporting mods than you
Most of the big WHP numbers done through HP tuners is achieved through 1BAD's tune. Its the beauty of being able to share data. His numbers are not inflated, stock I put down 252/259
Terminator also has the same mods as you and is making much more WHP than you. It could be the tune you are running.........
what "more" supporting mods do you have than me...
Charge Pipes
Synapse Intercooler
ZZP catless Downpipe
Hahn Catback
Airbox mod with K&N drop in filter...
Only thing I am missing is a **** with your car intake!
Charge Pipes
Synapse Intercooler
Hahn Catback
Also a bit more detail on the tune you "wrote" psychosteve, from what I hear it was just a tweaked Hahn BSR Map....
I have been trying to tell people not to put these intakes on the cars, but people just like the pichooie sound
