Quick PCM question
Old 02-25-2015, 09:24 PM
sheape's Avatar
Arrow Quick PCM question
So i am in the process of swapping a bad 2008 LE5 motor over for a 2007 LE5 motor will it be plug and play or do i have to get a tune to recognize the new motor? thanks for the help
Old 02-25-2015, 09:35 PM
hotrdr's Avatar
With both motors being le5....Should be plug and play. As long as all sensors are in the same place with same plug. You do need to relearn the crank sensor. Any shop should be able to do that
Old 02-25-2015, 10:38 PM
Jesse's Avatar
You don't need to make several threads across the forum to ask one question.
07 LE5 used the E67 computer
08 LE5 used the E37 computer
But they are almost identical. You should be able to swap all your stuff with no problem once you have a CASE learn done.
brandon04
10-21-2015 07:04 AM
dennis69
10-20-2015 07:39 AM
patooyee
10-15-2015 05:11 PM
Extremespeed
09-29-2015 04:34 AM
Iceberg
09-28-2015 01:31 PM
Quick Reply: Quick PCM question
