say it aint so?
Old Oct 26, 2008 | 01:13 AM
hatrickstu's Avatar
say it aint so?
so i slapped on the 2.85 (have been running stage 2 pulley) on the 42.5 injectors. i was actually hoping it was going to be lean as **** because i have been patiently waiting on my harness for the 60's which will be here monday. low and behold the tune actually seems to like the 2.85 better than the stage 2. i have the commanded afr's at 11.8 and the 2.85 is right around 11.8-12.1 for the most part in the 50* air. can this really be? i thought for sure the 2.85 would be too much for the 42.5, but the wideband appears to indicate otherwise, ill get some logs to verify this, but does it sound reasonable?
Old Oct 26, 2008 | 01:14 AM
SlowBalt_06's Avatar
yea will lean you out abit but its your duty cycle your gonna go static and knock..should anyways
Old Oct 26, 2008 | 01:16 AM
BLAZIN07SS's Avatar
I'm too JDM for you
do you know what your IDC's are yet? mine are 122% on a 2.9 but my commanded air/fuel is 10.8
my car doesnt knock at all. 22* of timing and 122% IDC
Last edited by BLAZIN07SS; Oct 26, 2008 at 01:16 AM. Reason: Automerged Doublepost
Old Oct 26, 2008 | 01:17 AM
**** with a 2.8 with colder plugs..i was knockin 5 or 6 degree's..with the stage 2 tune
Old Oct 26, 2008 | 01:20 AM
BLAZIN07SS's Avatar
I'm too JDM for you
i am on the 2007 version of the gm stage tune though, its completely different than the 05-06 tune. car holds 22* of timing all the way to 7,000rpm with no knock and my only cooling mod is an HE. pretty crazy when you have both versions of the stage tune in front of you and see all the differences
Old Oct 26, 2008 | 01:21 AM
damn i need to get that newer version
Old Oct 26, 2008 | 02:00 PM
Gabi's Avatar
careful with that!
i got the 2007 stage 2 tune and i get knocking from 5.5k-7k rpm
every car is different
now im looking for someone that tune me since i got some parts that needs tuning
Old Oct 26, 2008 | 11:01 PM
jeanbalt's Avatar
what do you scan with and what level octane ?
Old Oct 26, 2008 | 11:19 PM
BLAZIN07SS's Avatar
I'm too JDM for you
my interceptor scan gauge but i log with my friends hptuners. 93 octane pump gas
Old Oct 26, 2008 | 11:21 PM
1badBlueberrySC's Avatar
You suck Stu
Old Oct 26, 2008 | 11:24 PM
JimzSS's Avatar
my a.f.'s are fat, 11 to 10 or less, from 2500 to 6500 with 2.8" and stage tune only, can't read my knock. 22,000 miles and counting, I just don't hammer it everyday, all the time.
Old Oct 26, 2008 | 11:25 PM
I used to run a 11.9-12.2 on a 2.85 and 42s but that was tuned... your IDC's are going to be off the chart though!
Old Oct 26, 2008 | 11:27 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you know your a baller when your IDC's are 122%
jeanbalt's Avatar
very wise - if you are running anything smaller than the stock pulley
due to strict gm standards
some cars are able to handle timing better than others
that's why the gm tune is the way it is
It runs cars safe ... that's why hp tuners can improve performance
Old Oct 26, 2008 | 11:30 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yeah. lol. wonderful GM tunes. my IDC's wouldnt be so high if the stage tune didnt command 10.8a/f
the car looks like a diesel when i floor it cause its so rich. lol
Old Oct 26, 2008 | 11:36 PM
jeanbalt's Avatar
lmfao -- yeah when I scanned a guy I tuned I was ...and wasn't surprised
they have to put it that way otherwise $$$$$$$ down the line
unless some guy at gm said pick a number ... and the monkey said
I was pleased to see
when i plugged my tune they didn't go above
100 % ... I'd have to check again what the top % was
Old Oct 26, 2008 | 11:46 PM
Raven SS's Avatar
if ur injectors arent going static ur pcm will command a certain afr and ur car will do it (if tuned right) unless it just cant provide the fuel...changing pulleys wont lean u out if ur car has a properly working maf, a good tune, and injectors that can provide the right amount of fuel
