supercharging 2.4
im looking to buy the zzp stage 2 supercharger for my 06 2.4, do I have to get a wideband o2 sensor? and the kit comes with a flashed pcm but I still need to take it somewhere to be tuned right?
A wide band would help to read your air/fuel ratio. If u could afford one I would say get it and you can get ZZP can tune but it would be better if u get a better tune from trifecta since your 06
Piece together your own kit. Cheaper
alright ill get a wide band then and does trifecta have a website? im New to all this tuning ive never dealt with it before
where would I find everything to piece together my own kit if I would do that?
people on here sell kits all the time
Ya just google trifecta performance and if not there should be local trifecta dealers near you
More than likely you will save money if you piece together your own kit; You also NEED a wideband, you dont necessarily need a boost gauge but you need to have a wideband to be able to watch your air/fuel ratios and a wideband is also used in the tuning process.
Check out beck's SC build and Gene Culley's SC build; Those two helped me the most when I did mine. Where to buy, Look on here and dont rule out craigs list. A local guy for me totaled out his 06 SSSC and I was able to pull everything off his car that I needed and he gave me a great deal. I recommend HPTuners. While I haven't used trifecta for tuning; my tuner uses HPtuners for my 06 and we are doing pretty good I think. TVS-17psi, 23degrees timing, 11.4 A/F, 0KR |
Oh ya for some reason I thought 05-06 LE5 couldn't get tuned by HPT but it's the L61 05-06
Hptuners is best if u find a good tuner
alright thanks for the help I appreciate it
