supercharging 2.4
supercharging 2.4
im looking to buy the zzp stage 2 supercharger for my 06 2.4, do I have to get a wideband o2 sensor? and the kit comes with a flashed pcm but I still need to take it somewhere to be tuned right?
A wide band would help to read your air/fuel ratio. If u could afford one I would say get it and you can get ZZP can tune but it would be better if u get a better tune from trifecta since your 06
More than likely you will save money if you piece together your own kit; You also NEED a wideband, you dont necessarily need a boost gauge but you need to have a wideband to be able to watch your air/fuel ratios and a wideband is also used in the tuning process.
Check out beck's SC build and Gene Culley's SC build; Those two helped me the most when I did mine. Where to buy, Look on here and dont rule out craigs list. A local guy for me totaled out his 06 SSSC and I was able to pull everything off his car that I needed and he gave me a great deal.
I recommend HPTuners. While I haven't used trifecta for tuning; my tuner uses HPtuners for my 06 and we are doing pretty good I think. TVS-17psi, 23degrees timing, 11.4 A/F, 0KR
z28addiction
09-28-2015 12:03 AM
