Timing?
Originally Posted by memphisr24
And you were supposed to give me a ride in your car....you never did
I wanted to see what 300whp in a coablt is like
But I noticed some people on here are runing 20+ degrees of timing on pump gas unless they are bsing. Blown4banger, did the heat exchanger and dual pass intercooler end plate make it easier to raise timing?
On a race tune, I have octane learn disabled by copying the high octane to the low octane table.
I'm not so sure about that. It even says on HP Tuners, that the low octane table is the table used in the case of MAF failure. Meaning the car isn't using the MAF sensor, but rather the VE table.
wait til you get to see what a 450 whp cobalt is like..... it's coming... and soon....
and I was running pump gas (93 mobil) and 70% meth (on the meth inj of course).... car ran sick like that,, never any knock... except when I let off the gas between 1st and 2nd (and that was only like .5 degrees).... car was beasting... but after seeing so many blow up... I took off most the mods until my motor is finished... then all hell is gonna break loose... just hopefully not the tranny of course..
and that was an old log run too... displayed are my new settings... but they weren't used on that run which is why you see some data missing... I might have a newer one let me check
Commanded AFR your going to want to change your PE table EDIT* Engine>Fuel Control>Power Enrich>then go to the one right underneith where it says HOT, its something like PE multiplier. Say your PE multiplyer is at 1.30, then your commanded AFR is roughly 11.3. Here
1.30 = ~11.3
1.29 = ~11.4
1.28 = ~11.5
1.27 = ~11.6
1.26 = ~11.7
1.25 = ~11.8
You disable octane learn by going to: Engine>Spark Control>Timing Advance>High Octane. Then highlight ALL of the cells in the high octane map and hit control>c, then go to the low octane map, highlight all the cells and hit control>v. If you did it right, most of the cells in your low octane map should change into pretty colors. And thats how its done.
1.30 = ~11.3
1.29 = ~11.4
1.28 = ~11.5
1.27 = ~11.6
1.26 = ~11.7
1.25 = ~11.8
Originally Posted by Blown 4-banger
Looks like you got some knock on there. Also I notice your IAT2 was 135 degrees after only like 5 seconds at WOT.
and with PE table it depends on what your stoich afr is at for those multipliers to work correctly.. I know with the Intense tunes they change it from 14.69xxx to 14.7988 or something like that, so your PE commanded would be a bit different if you are modifiying it.
Log "knock learn factor" as a PID and it will show you how close to your high octane table you're actually running. Values of 1 will be the high octane table value. Values closer to 0 are approaching your low octane table. If you have values of 0.8 for instance, it shows you pushed too much timing and the PCM will be pulling it for that cell regardless of knock detected for a certain period of time.
The PCM moves timing towards the high octane table at a rate 10 times slower than it will learn low values due to knock.
Edit: I can't spell
On both my race gas tunes, I have the high octane map copied to the low octane. On my pump gas tune I copied the high octane to the low octane and subtracted 2 degrees from the low octane.
Yep thats about how much timing I run on the pump gas tune. Its no fun, yeah its fast, but with a simple reflash it could be CRAZY fast! I couldn't take it so I flashed my race gas tune on it and threw in several gallons of 101 octane. WOO HOOO!!! 25 DEGREES OF TIMING FTW!!!
NO TRACTION IN FIRST OR SECOND FTW!!!
Clutch slip FTL
