VE tables question.
Old Aug 5, 2007 | 02:05 PM
SJSchafer's Avatar
VE tables question.
Does anyone have a smooth VE table for stage 2? I ran about 8 runs adjusting my VE by afr error % and the areas that I log are looking pretty good. I cannot hit enough areas to get an idea of some of the curves though, so I can smooth them out. My mods are in my sig.
Just for referrence, I am tuning in open loop SD untill I get my VEs in line, then I will enable MAF and tune MAF before going back to closed loop.
Also I noticed that I am getting quite a bit of KR in open loop SD, but mostly in the lower RPMs.
Old Aug 10, 2007 | 04:47 PM
SJSchafer's Avatar
Bump?
Old Aug 10, 2007 | 04:55 PM
Kaisoboy's Avatar
This link might help yah out.
https://www.cobaltss.net/forums/tuning-131/1st-setup-injectors-flowrate-rate-modifier-min-pulse-width-pw-adder-69454/
Old Aug 10, 2007 | 05:26 PM
Kennyspec's Avatar
i noticed that in SC you get a LOT of burst KR. once the MAF is enabled lots of it goes away.
Old Aug 10, 2007 | 05:42 PM
SJSchafer's Avatar
Thanks for the refference. Tough to tune PE mode in SD around here, but I guess that is where I need to go. For me, when I am PE, the RPMs climb a bit too quick to get reliable readings unless I am in 4th or 5th which gets me going pretty fast.
Yea, I think it's because in SD our cars use the high octane tables.
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Bohb
Sep 27, 2015 09:11 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
Getaway_Driver
Sep 8, 2015 09:41 AM
