your timing.
Rent me! per hour
your timing.
max, WOT.
for instance, i can cram 28 degree's down my car. this doesn't mean it likes it.
whats everyone doing for max timing. 23? 25? 12? 18?
keep in mind, i do have a huge window to play with, since the water injection. so i can add, and subtract at will.
Intense plate it too thin to tap for the meth nozzle from what I've seen. the t.b. spacer works good though, just need to get the solonoid valve too so vacuum doesn't suck the meth into the motor and flood it.
Rent me! per hour
hmmmm.
i have 60's just sitting in my basement right now collecting dust. im basically at max on the fuel and timing. it has nothing more in it. from 2500-7200 on my "happy" map it sets at 25.5 degree's. cramming 27 gains 2 hp, but also running a bigger risk of eating something as well.
maybe i'll drop pulley sizes, throw the 60's in, and work from there. the main reason behind this is. im stuck. i feel like i hit the wall with the 2.8
Rent me! per hour
oh i know they are. the reason i asked this. ***** out, 12.0 a/f 25-26 degree's of timing on 91 octane and meth injection. the car put down 245/229. low numbers yes. keep in mine it was well over 100 degree's inside the shop, and about 75-80% humidity. it had nothing left in it. there was nothing else i could do to it to make anymore power.
Rent me! per hour
dunno, still kicking around the idea.
this particular dyno does not have any air flow. it has a small squirrel cage fan on the front of it. thats it. the door is a good 30 ft or so away from the dyno. so needless to say, the iat's were over 100 degree's. i do understand heat plays a huge roll in power.
Rent me! per hour
Rent me! per hour
