TTR engine/trans mounts
I doubt it but Powell makes mounts for the F23 and if you want TTR's inserts PM me I have a set that I'll sell for not too much. Both stock mounts with the inserts not in them and an upper mount.
Installed my automatic trans mounts Tuesday and it took all day because the rack/pinion is so close I couldn't get to the bottom bolt on the rear mount. Also, the cross-pin was .15" too wide for my REAR ONLY stock trans mount so I got a bench grinder and took off that small amount. Finally, had some issues with the holes not lining up that jacking the trans took care of quickly.
Stock trans mounts were absolute bullshit and had broken completely. Same for my control arm bushings, the passenger bushings just popped out of the control arm!!!
