TWM Performance TWM Performance is a proud Supporting Vendor
TWM please fix our shift linkages!
Old Aug 8, 2010 | 01:54 AM
RYRO14's Avatar
I have been having an issue with my linkage popping out under the shifter with the ball-socket connection, and I know other have been having the same issue and I figured you guys might be able to help us out.
Old Aug 30, 2010 | 09:16 AM
RoadconeTuning's Avatar
mine did this twice last night... is there something that can be done?
Old Aug 30, 2010 | 09:23 AM
coopercharge's Avatar
I had the same issue in my 2007 LS I ended up replacing that ball socket connector because it wasnt as resilliant and it should be. It's not TWM's Fault that little plastic socket just sucks is all.
Old Aug 30, 2010 | 09:30 AM
Its only like 15 bucks from the dealer if I remember right.
Old Aug 30, 2010 | 10:31 AM
I have a stock shifter and 6800miles on the car... lol
Old Aug 30, 2010 | 02:42 PM
TWM Performance's Avatar
Hey guys,
It's a project we're working on. Basically replacing the stock plastic part with an aluminum part and a much more solid attachment point. No ETA at the moment, but keep an eye on our section for any further details!
Thanks,
Frank
Team TWM Performance
Old Oct 9, 2010 | 04:23 PM
RYRO14's Avatar
Any update on this?
Old Oct 9, 2010 | 04:30 PM
army_greywolf's Avatar
take shifter out, remove ball with vice grip, the threads are something like M6-1.25 pitch or something small, you will need two fender washers, a 1.25 inch long bolt, RED loctite, a drill, your original plastic socket end to the shifter, about thirty minutes of your time and the slightest tweak to get it to feel right.
Old Nov 28, 2010 | 11:18 AM
RYRO14's Avatar
Updates?
Old Nov 28, 2010 | 11:45 AM
ecotecon18s's Avatar
Hey Ry I'll just trade you my Hurst for your TWM... lol
Old Nov 29, 2010 | 09:24 AM
Hey guys,
We have some great updates! The clamp is tried, tested and works AMAZINGLY! There are only a few more tests to do and you guys should have an update by the end of this week...We're almost there guys, so just be patient for another few days!
To hold you all over, here's a teaser of our prototype piece:
Old Dec 3, 2010 | 04:13 PM
Check out the official Pre-order thread going on RIGHT NOW!
https://www.cobaltss.net/forums/twm-...-order-235464/
Old Dec 3, 2010 | 04:15 PM
umrdyldo's Avatar
how hard is install on this piece. Would be smart to have one around when stock piece fails.
Old Dec 3, 2010 | 07:46 PM
so does it keep it from flying off the base of the shift handle
RaginChopsuey
Oct 27, 2015 01:27 PM
dieGone
Oct 1, 2015 06:27 PM
footballplaya3k
Sep 30, 2015 09:39 PM
2009blackSS
Sep 30, 2015 05:57 PM
DocSvensk
Sep 27, 2015 02:24 PM
