Wanted - What to buy - All categories Place request for items you would like to purchase.
2006 SS/SC Turn Signal Lever
Old May 13, 2014 | 09:12 AM
blueLNFftw's Avatar
Somehow mine is complete shattered.
Needs to have auto lights, clean, and good paint on it. Black. Must work with the SS clock spring.
This is the lever used to activate those things on the car that magically show others you are intending to change velocity.
Shipped to 32164
Old May 13, 2014 | 09:32 AM
Dream20b's Avatar
so you're going to use your turn signal on to indicate you are going to change speed?
Old May 13, 2014 | 11:30 AM
blueLNFftw's Avatar
velocity is speed and direction.
Old May 13, 2014 | 11:50 AM
Dan_G's Avatar
I like this site for locating parts:
Chevrolet Parts, Cadillac Parts, GMC Parts and Buick Parts powered by Nalley Buick GMC | Nalley Buick GMC Brunswick
They have diagrams and can locate most parts with GM part numbers.
I believe you might be looking for a "SWITCH. Headlamp Dimmer. Turn Signal Lamp." - this is GM part number 20940099 = AC Delco D6254E. You can phone pretty much any GM parts dealer and they can verify this.
Then you pop this into Amazon and find the part costs ... wait for it ... $22.92. Gotta love the prices on these GM parts.
So if this is indeed the part and it's $23 from Amazon brand new ... I would just buy it from Amazon and not bother with a used one. You should verify the part number for yourself before buying
Good Luck
PS - look at the Amazon reviews ... someone used this part on an 06 Cobalt SS ... so I'm pretty sure this is the part.
Old May 13, 2014 | 01:39 PM
Dan_G's Avatar
I just noticed the washer lever is $21.38 (ACDelco D6249D). So even if all the levers were broken off your steering column ... it's less than $45 (shipped) to repair.
Old May 13, 2014 | 01:51 PM
blueLNFftw's Avatar
Damn.
Thanks a bunch bro!
Bought it and grabbed the IAC my clerk needed too.
Old May 13, 2014 | 01:59 PM
DFZ24's Avatar
mine broke in a way that the turn will not stay, i had to hold it.
i try the DIY fix but didnt work, so ended up buying a new one
Old May 13, 2014 | 02:14 PM
Dan_G's Avatar
Great, no problem. Looks like pretty simple job to swap it out. The replacement procedure for a 09 is:
1) remove the left side instrument panel trim panel;
2) remove steering column trim covers;
3) disconnect electrical connectors;
4) release plastic retaining tabs to remove turn signal multifunction switch.
Yours should be similar.
Old May 13, 2014 | 02:20 PM
redcobalt07's Avatar
Shipped to 32164
a turn signal doesn't say you are changing speed at all. And velocity is the change in speed
Old May 13, 2014 | 02:58 PM
makememad's Avatar
If ur as cheap as me, you could plastic weld it back together, thats what i did. It holds, for now.
Old May 13, 2014 | 03:30 PM
iToastie's Avatar
Mine just broke a few days ago, wont hold the left turn signal.
I'll order one of those Thanks
Old May 13, 2014 | 03:40 PM
06cobaltncng's Avatar
Velocity is the rate of change of the position
of an object, equivalent to a specification of
its speed and direction of motion, e.g. 60 km/h
to the north. Velocity is an important concept
in kinematics , the branch of classical
mechanics which describes the motion of
bodies.
and where tha fack you been corey???
Last edited by 06cobaltncng; May 13, 2014 at 03:40 PM. Reason: Automerged Doublepost
Old May 13, 2014 | 04:18 PM
CrateEngineDepot's Avatar
Link
Old May 13, 2014 | 09:05 PM
iToastie's Avatar
$43 for the exact same part sold on Amazon for $23 mentioned above? I know you're a vendor and all, but no thanks.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
dieGone
Oct 1, 2015 06:27 PM
Iceberg
Sep 28, 2015 01:31 PM
