Dodge Stealth vs. My SS
Originally Posted by p7x
If he does anything he'll probly go with a single turbo but why the new engine. Aren't the R/T and R/T TT engine the same 3.0 V6???
Originally Posted by ralliartist
that's def. possible. like i said. the base models aren't quick at all, even with bolt-onz. they need FI bad!!! but the TT's are hella fast! especially from a dig!
The newer 3rd gen base models got a different engine which was actually a sohc I beleive which sucks for them ... the older base models all had the 220hp 210ft/tq engines
Originally Posted by SwizzDSMSS
haha I smoked a VR4 hella bad from a 40 roll. VR4 is overrated like Duke!
Originally Posted by Nocturn
maybe stock, but Vr4s are beast with even minor mods, they are 13 second cars, which from last I checked is faster than the CSS.
A buddy of mine owned a 94' Dodge Stealth R/T TT. And that thing was fast. Plus it had AWD. These cars are 13 second cars stock!! The only problem with these cars is that if u need a part for them GOOD LUCK!! Parts are so hard to come buy and if you do get a part for it, it comes straight from Mitsubishi and it's expensive as hell. But there was no way that this dude raced an R/T TT
I raced my boddies 3000 GT SL at the track. the best time he has ever put down was a 16.5. They are slow and heavy. the TT/AWD one is even heavier due to the AWD drive train/assembly. Stock they are not much. But the are easily moddable though. But if you do your research, RT's and VR-4s are very expensive to up keep, and they tend to break **** a lot. Trannys are a big problem in those cars, and cranks seem to go bad also, after around 400 or so to the wheel.
Um, no its the Transfer case that is the problem on those cars, not the tranny. And the SL is a 220HP FWD POS. Add 100 HP and give it AWD and its a different story, yes they are heavy but its still around what a GTO weighs. It's still a faster car, no one would brag about beating a Cobalt LT, now would they, so don't talk about racing the SL or base model when its not the peformance version.
dont know where to start ... first with the statement of all vr-4's running in the 13's ... no ... and second if you were on 3si for 3 years I am sure you would know this unless ... your mag racing then the sky is the limit I suppose.
Also while the SL is not the premium version it is still considered a sporty car and puts out around the same power that the SS does ... if he gets into a race with one why not let him tell us about it? thats like saying no one can now post a race between a mustang gt since it wasn't a cobra or better
Yes its equal power, but it weighs 1000 LBS more, why not post races with V6 F150s and Non hemi Rams...whats the point.
IM not magazine racing, just look at the figures, take an evo, add 50 HP (depending on year), and about 600 more LBS and its going to still be a 13 second car, high 13s but still 13s.
Originally Posted by SSkeeter
You are smoking crack. A TT R/T or 3000GT VR4 would straight up eat the hell out of a stock SS not just "pull slowly". Especially from the highway. Put down the pipe.
haha you make me laugh, they are 1 second faster in the quarter mile on a perfect run.... on the highway its close.. they'll prolly still pull on a SS but the SS wont get raped like everyone thinks
Originally Posted by dimeo09
my friend with a vr-4(stock) runs consistant 13.5's
Originally Posted by wasey13
I call BS! There is no way a stock VR-4 will see 13.5s. It takes a lot, I MEAN A LOT to get them to hit 13.9.
he has one of the last years they made em, and hes experienced and i guess he did some boost bypass mod but thats all
If you beat on any year VR4 it will hit 13's every time. The 99s could hit very low 13s everytime. If you want your clutch, tranny, and tcase to last you will run low 14s. The trannys on them are the big issue. Very few vr4s or rt/tts make it past 100k miles on the stock tranny. Mine lasted to 77k.
The base model up until 97 did not have the 222hp DOHC v6. It had a SOHC v6 and I am guessing but I think 160hp. The SL had the DOHC 222hp v6 up to 97. 97 and 98 NON turbos all had the DOHC I believe. The SOHC models ran 16s. The DOHC models ran consistent mid 15s with a few people actually breaking into the 14s. The fastest I had ever seen was a 14.4 in a DOHC.
