me vs high 13 second GTP **VID**
my buddy came down from Rockford illinois.
he has a Grand Prix GTP with the following mods...
# 3.5" Pulley(stock is 3.8") on about 12psi... stock is 5psi
# P&W Plog (that is a ported exhaust manifold)
# ZZP PCM
# AutoLite 104s
# 180 Tstat (stock is 194)
# 3'' DownPipe
# Deleted cat
# No ubend
# No resonator
# FWI
Here is HIS speedo Video.. as you can see it has great topend.. http://media.putfile.com/GTP-30-120
all i got is the Ingalls and the GMPP touring.
We did a few races... im only going to post the ones which were clean races...
all the other ones.. (roll and dig) that i am NOT showing are either because..
a. i shifted too fast and didnt engage 2nd gear (seriously.. cable shifters SUCK)
b. Clutch slipped at high rpm shifts (once again shifting too fast)... man i miss my SHO.. that thing could handle it
so weeding those out... we have 2 races.
35mph, and 40mph.
35 - ~100mph = http://1997gtp.net/Videos/SSvsxr7man46_35mph.wmv
40 - 140mph = http://1997gtp.net/Videos/SSvsxr7man46_40-140.wmv
^^^ in this video my buddy got scared who was taping.... so he shut the camera off 2 seconds earlier... as you can see right before it ends i start to gain forward... i ended up a nose ahead and still pulling (go DOHC! )
When he comes down next time.... in a few months he will have a 3.4" pulley and a set of 1.9:1 rockers (its a pushrod thing )
I will have my stage 2 kit with ex. ho. manifold.... so i should walk him easily
# ZZP PCM
# AutoLite 104s
# 3'' DownPipe
# Deleted cat
# No ubend
# No resonator
# FWI
35mph, and 40mph.
that gtp is slow, race one with a 3.25 pulley,160 degree t stat , thrasher custom tune , slp long tube headers , no cat , flowmaster cat back, shift kit , ported throttle body , plugs, wires , and dot compounds then tell me how you do, with those mods i just listed it should be able to achieve a 13.4 consistently , and there is NO WAY he is running 12 pounds of boost on a 3.5 , a 3.25 barely yields 11 check your numbers
good runs. its just with that free flowing exhaust to he will not push that unless he has a smaller pulley than he is telling you
did i miss something he never claimed the gtp he raced was fast just said high 13's
ok.. there is no need to debate this...
incase you didnt know... i have a GTP.. and have had it for 3 years now.. it runs mid 13s... and i basicaly know everything there is to know about it. (so its not like im going off what he said)
he has 12 psi on his car..
i measured his pulley, and both his boost gauge and my scanner read 12psi... leave it at that.
here is my GTP
here is my GTP
thanks lsjwannabe
also.. since you think you know so much about the grand prix Red2.4SS/SC,
he has a 99 GTP... 99 happens to be the year of the freak.
there are a handful of grand prixs out there (most from 99) that run SIGNIFICANTLY faster times then they should with the given mods... its just how the car is.
and look at his SPEEDO video... i think that is pretty damn fast for a 3.5 " pulley... there was a multiple page thread/debate over at www.clubgp.com because of his speedo video. people did not believe he had a 3.5" pulley on there
car seems like it moves good, the thing is it has the ported mani and dp which will in turn lower the boost so what if he didnt have those mods? thats a lot of boost for a big pulley
yea like i said.. we cant figure out why....
my car has a 3.4" pulley.. and i get 11psi....
but then again i have Headers, and rockers so my PSI will be less then a car without aftermarket headers or rockers
nothing else is out of the ordinary, he is gettin no knock either.... so he is just not gonna complain and be happy with what he has
wish mine responded that well
yea.. after going through 2 engine with my GTP, i wanna stay with a warranty...
you dont know how tempting it is though for me to rip open the valve cover and throw some cams in here... oh well..
i need this warranty
you don't want to go lower then me i run a 2.5 and every mod besides full exhaust which will arrive shortly surprisingly no blown piston's or broken axle's yet im lucky. But my dad and bro work for the dealer so i kinda don't have to worry about the warrenty
gtp's are SLOW, unless you have 10,000 , ill pull a you here " i used to own one also" and it ran LOW 13's with everymod i listed earlier , stock psi on a m90 is 6 lbs not 5 and a 3.5 pulley WILL NOT put you at 12 lbs GUARANTEED , also arent you on gp-owners.net or grandprixowners.com , that car looks familiar , and as far as your 99 gtp statement thats all subject to opinion thats like saying that the 06 cobalt ss/sc is significantly faster than the 05 bc there are more 06's with better times than 05's with the same mods you get what im saying ??
Reading about these SS/SC's, I've found that stock or mildly modded ones run mid to low 14's. Even the stage 2 averages low 14 second runs. So, if this GTP is running high 13's, then you shouldn't be able to beat him. Somehow I think he only ran a high 13 once or one of you sucks at driving.
also, about the stage 2 times... a stage 2 cobalt with a breathing driver can hit 13.9. its all about the launch. im sure the GTP has the launching advantage. these crappy times that are being referred to are those of crappy drivers.
think about a roll race between a stage 2 cobalt and a stock STi. its waaaaaaaay different than a dig race.(start a new thread if this is gonna become a huge debate, dont hijack the thread)
