Raced another SS\TC
Raced another SS\TC
I'm starting to get sick of the SS\TC because I ran another one today from a dig and killed it worse then the one2 weeks ago. Reason I'm pissed is I know the SS\TC is totally capable of giving my TBSS a good race even with my mods, but both guys told me they fucked up with either the launch control or the no lift shift. I test drove one when the first came out and it didn't seem that hard to get use to it.
Yea I guess. I went from a SS\SC which everyone wanted to race to a TBSS which I can barely get a race so when one comes along and it sucks because the dude tells me he doesn't know how to drive his car I get pissed.
I love the TB/SS I love the way their body lines are and smooth, I raced one umm, about I want to say a month and a half ago, I don't know what the guy had other than and exhaust(for it didn't sound like a stock or look like a stock one) and he has a sticker for an intake but that doesn't mean he had one. Needless to say from a stop light we went at it. He put like 5ft on me out the box but, I pulled it back and had 3 cars on him by 70mph and was still pulling hard when I shut down shortly after 70. Note I have a built 05 SS/SC cobalt. i want to race one at the track with my 09 SS/TC which is modded too. I'm curious how it go down.
I love my TBSS, but stock no lower then a 13.9. Now a tune is a must with these trucks! A tune, intake, stall, and efans and your over a full second faster.
Yeah I own both an SS/SC and SS/TC
05 SS/SC
Exterior Modifications:
Debadged
Shorty Antenna
Painted Black Head Light Housing
Super White Led Corner Lights
Skyline Style Tail Lights Functional
Team Rev Banners
Custom Front Upper Grill
Painted Red Brake Calipers
Stock Rims Painted Black
10K H.I.D. Conversion Kit
Evo 10 Bumper Mod
Interior Modifications: Custom Dash Inserts
Blue Led Module Kit For Dash Cluster
Three Pod Pillar (Cobalt 30psi Boost Gauge/Water Temp/Oil Pressure)
Custom Dual Cluster Pod (Aem Wideband/Empty right side as of now.
Avic-D3 In-dash Dvd/Nav
Led Interior Lights
Performance Modifications:
Pistons 10:5.1
Custom Sleeved Block
Built Head
Custom Ported/Polished Head
7,200 Rev Limiter
Custom Balance Shafts Delete Kit
Custom A/C Delete Kit
Custom Hardened Oil Pump Gear
ARP Head Studs
ARP Main Studs
Cometic LSJ MLS Head Gasket
Spec Flywheel
Spec Stage 3+ Clutch
GM Stage 2 Belt
ZZP Adjustable Tensioner
Custom Ported Intake Manifold
Custom Ported Supercharger
Coolingmist Meth/Injection Kit
2.7 Pulley
Custom Stage 2 Hub
Supercharger Coupler
Custom 3" Intake
3.5” Throttle Body off GM 4.2L thaoe
Custom 3" Under Axle Exhaust System
JBP Vortext Header
OTTP Second Gen Heat Exchanger
Meziere's Aftercooler Pump Custom Mounted
Dual Pass Endplate
HKS Oil Catch Can
Fuel Filter
Walbro 255 Fuel Pump
60LB Injectors W/Harness
NGK Spark Plugs(Same As Time Attack Cobalt)
NS-ll Performance Tires Drag Radials
Stage 2 Axles
Tenzo-R Lowering Springs
Turbo Tech Rear Sway Bar
Drilled & Slotted Rotors/Ceramic Pads
Trans Mount Bushings/Custom Shims
Upper Billet Engine Mount
Polyurethane Control Arm Bushings/Custom Shims
Custom Solid Driver Motor Mount
Custom Tune Hp/Tuners
Painted Supercharger/intake manifold and whole motor(Black W/Some Red Accents
09 SS/TC
Custom Hardened Charge Pipes
Bigger Intercooler
Poly Trans Mounts
Solid Upper Motor Mount
Custom 3" Intake
Custom 3" Cat less Downpipe
Custom Color Matched Dash Trim
Custom Tune
Custom Painted Headlight Housings
Led Taillights
Lowering Springs
Custom Painted Black Rims
think thats it
some pics
05 SS/SC
Debadged
Shorty Antenna
Team Rev Banners
Evo 10 Bumper Mod
Led Interior Lights
Pistons 10:5.1
Built Head
7,200 Rev Limiter
ARP Head Studs
ARP Main Studs
Spec Flywheel
GM Stage 2 Belt
2.7 Pulley
Custom Stage 2 Hub
Custom 3" Intake
JBP Vortext Header
Dual Pass Endplate
HKS Oil Catch Can
Fuel Filter
Stage 2 Axles
09 SS/TC
Bigger Intercooler
Poly Trans Mounts
Custom 3" Intake
Custom Tune
Led Taillights
Lowering Springs
think thats it
some pics
Last edited by OneCOLDBIZL272; 06-18-2009 at 02:52 AM. Reason: Automerged Doublepost
yeah I dont remember the times dead on theres packed away some were cause i just moved in the past two weeks of hand but i do remember the trap speeds thou, i traped 116 in the 05 SS/SC and traped 113.6 in the 09 SS/SC
edited i remember they were some where in the 12's
I totally love the cars! IMO the Cobalt SS\SC and SS\TC are the nices FWD sport compacts on the road. My SS\SC on sportlines, 5% tint, blackedout tails, and wingless made me drool. My TBSS is setup the same way, but I do like the way the LS2 engine and exhaust sound better.
