15 Inch Rim on a SS/SC - Seriously.. Must be done!
Old Jun 28, 2011 | 02:58 PM
Bloomk's Avatar
k guys, i have beenreading thru stuff for hours and decided to just post my question. I have a ss/sc that i need to put a 15 in wheel on (for some good slicks). I do NOT want drag radials or any other size wheel so please do not suggest that Allthe threads i find seem to be telling people to run 16's or 17's.. i want a REAL slick (Maximum traction). We are building an actual race car (street use will be limited)
any help would be much apreciated.
Old Jun 28, 2011 | 03:07 PM
Chevycobaltss3's Avatar
U need to get the 4 bolt setups from a ls or ltft and the u should be able to use a 15
Old Jun 28, 2011 | 03:11 PM
ssyellow's Avatar
Check out the LSJ brake section. Any info on the car your building?
https://www.cobaltss.net/forums/drag...combos-250374/
Old Jun 28, 2011 | 03:14 PM
EXsoccer1921's Avatar
Centerline makes a few 15s in a 5x110 pattern wide enough for a good slick. if you're not on coilovers you'll need a 5mm spacer so the tires will clear the strut.
Old Jun 28, 2011 | 03:35 PM
Sweetsandman's Avatar
Contact cmiller on here. He has an SS/TC and did the LSJ brake swap and runs 15 inchers. He shaved down the calipers a bit IIRC.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
DANRICKARD
Oct 1, 2015 12:08 AM
z28addiction
Sep 28, 2015 12:03 AM
Dirtybutwhole
Sep 26, 2015 03:29 PM
