18's without recalibrating speedo?
im fairly new at this...i have a 2007 cobalt ls 5 speed 2 door and was wondering if i could put 18's on it without recalibrating my speedometer? if so what size tires could i go with?
i have the hub caps...yeaaaa.......195/60/15...the tire shop i used to work at said the biggest i could go with is a 205 40 17 but since the ss's came with 18's i was wondering if i could do the same
The SS/SC ride on P215/45ZR18, while the SS rides on P205/55HR17. You could put P215/35ZR18's on it and maintain your speedo calibration because that size 18 is the same diameter as the original P195/60R15's. Unfortunatly its not possible to reprogram the speedo in our cars, only the aftermarket tuners have that kind of access.
Guest
Posts: n/a
I have 225/40/18s on my 2.2 and they fit perfectly. at 80mph (on the guage)I am really doing 82.5 its not that far off, so I don't really care
If putting 18's on a Cobalt, the consensus is to use a 225/40R18. GM uses a 215/45R18 to give a little more sidewall. To answer the original questions, yes, it will fit perfectly. You can even lower the suspension (like the SS FE5) and still be perfectly fine. And yes, Dealers do have the ability to recalibrate the speedometers, but only to a degree. All the same, you can get it VERY close, to within 2 MPH.
Try this site to compare wheel sizes:
http://www.miata.net/garage/tirecalc.html
I just tried it using the numbers you provided and at 60MPH indicated you would be traveling 62.2, but like I said, the dealer can get it even closer.
As a comparison, I have the stock 16", which come with 205/55R16's. The difference with that tire is 0.5 MPH. I am lowered (Prokits), and have an absolutely perfect ride.
Last I knew the reprograms we can do are only recalibrations for proper ABS function. When we reprogram the vehical its the EBCM that gets recalibrated, the speedo in the IPC is unaffected.
