18x8 +35 offsset
Old Jul 26, 2010 | 12:38 PM
Lifter's Avatar
18x8 +35 offsset
Any one else here running 18x8 +35 offset? Thinking about getting the following;
http://www.tulipcitywheels.com/tcwst..._detail&p=2469
Old Jul 26, 2010 | 01:05 PM
Dart_SI's Avatar
i like those. in for if +35 is ok or not. btw i own a ss/tc, so keep account of that. what do u have OP?
i really want some tenzos but they dont have any 5X110 bolt pattern. lol sucks.
Old Jul 26, 2010 | 01:07 PM
SOHC24powa's Avatar
I've seen those on a few around. I'd like to get set myself. Just no red stripe for me.
Old Jul 26, 2010 | 01:19 PM
Lifter's Avatar
I'm running stockers. I'm hoping the +35 offset can handle the wider tires. They're significantly cheaper than EKM3s, and they look better too.
That's why I was hoping some peeps here had some info on +35s
Old Jul 26, 2010 | 01:22 PM
SylverSS/SC's Avatar
I got 18x8 TSW Nogaro's with a +40 offset. don't think that helps you much
Old Jul 26, 2010 | 01:29 PM
dandaman15's Avatar
How do they fit? The wheels OP wants will be similar just stick out 5mm closer to the fender. I think they will fit. The wheels I want are 17x8.5 +35 and everyone seem to think they would fit.
Old Jul 26, 2010 | 01:36 PM
Mine fit good. I've got them on an SS/SC lowered on sportlines. no rubbing issues or anything with 225 tires
Old Jul 26, 2010 | 01:38 PM
MikeyB's Avatar
Just to let you know these wheels have an extreamly cheap finnish and weigh a ton.
The EKM3's are much better quility, thats why there more expencive.
But for cheap rims the MSR are pretty good
Old Jul 26, 2010 | 02:00 PM
calicobaltSS's Avatar
Ive got the EKM 3's.....if ya want a few pics I have some I can post em later....im thinking about getting something else though....
Old Jul 26, 2010 | 02:05 PM
Lifter's Avatar
Yeah, I know they're cheapish quality. Know some peeps with MSRs and they said the finish chipped easy.
I originally wanted the EKM3s, but started shopping around more. Wanted a pattern but with more variety in color. Silver and black just seemed dull to me.
Thanks for the input everyone. Any one else know some one with/have some +35s? The more info the better.
Old Jul 26, 2010 | 02:07 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you only picked the most popular wheel out of the whole forum
Old Jul 26, 2010 | 02:08 PM
ls1fbody's Avatar
Haz l33t wheelz.
I'm running 18x8 +35 with no issues, i actually have spacers in the rear...
Old Jul 26, 2010 | 02:25 PM
ColeJJones's Avatar
Bannned
good thread. i have been asking questions simular to this. i was hoping to run +25s
Old Jul 26, 2010 | 02:56 PM
Lifter's Avatar
I am unsure of whether or not the +35 offset is going to be enough to clear the inner strut. But again, I am unsure. Hopefully there's some one around here that knows better.
I guess what would be the best info' would be if these wheels would fit with the stock suspension.
Old Jul 26, 2010 | 03:01 PM
ls1fbody's Avatar
Haz l33t wheelz.
uhhh....
06_SIC_SS's Avatar
psshhh go 18 x 8 + 15
Old Jul 26, 2010 | 03:08 PM
ls1fbody's Avatar
Haz l33t wheelz.
Stock is +42, that means the wheel mounting point sits 42mm from center. Generally, the greater the number, the closer the wheel is to the center of the car. The smaller the number, the further out it goes.
35 is less than 42, so a 35 offset wheel would be further out towards the lip of the fender.
Make sense?
Old Jul 26, 2010 | 03:09 PM
Lifter's Avatar
uhhh....
That does not answer the above question.
Old Jul 26, 2010 | 03:12 PM
ls1fbody's Avatar
Haz l33t wheelz.
I'm running stock TC struts and pedders springs. I'm dimensionally the same as stock, but lower.
No clearance issues. Also, see above post on offsets.
Old Jul 26, 2010 | 03:39 PM
BLAZIN07SS's Avatar
I'm too JDM for you
yes they fit fine. ran mine lowered on eibach sportlines with no issues either
Old Jul 26, 2010 | 03:40 PM
06_SIC_SS's Avatar
blazin did u ever measure up ur offset on the CCW's??
BLAZIN07SS's Avatar
I'm too JDM for you
17x9 +35mm
Old Jul 26, 2010 | 03:42 PM
06_SIC_SS's Avatar
nice and flush
Old Jul 26, 2010 | 03:44 PM
BLAZIN07SS's Avatar
I'm too JDM for you
nice and flush
yessir. rear lines up just past the fender. gonna stretch the rear to get hellaflush
Old Jul 26, 2010 | 03:46 PM
06_SIC_SS's Avatar
get wet son
im lookin at runnin an 18 x 8 + 10 .. currently doin some measuring but i think we'll be able to stick it in there.. thats another reason why i was hopin u measured urs since ur 9 wide
