18x8.5 +35 offset
Will these work for a base G5, or is the offset too low? I know someone was running a 19x8.5 with a +38 offset, and I was wondering if those 3mm would make a difference.
I do plan on droping my car on coilovers, and I was wondering if the offsets were too extreme for a decent drop on a DD |
Originally Posted by McFlurrey06
(Post 4506208)
Some people have rubbing issues with a +35 offset 8.5" combo. If you go with 235/40/18 tires and Peddars springs, you will likely be okay. You won't be able to go crazy low on coilovers, that's for sure! The Peddars springs keep the rear end a little higher than other drop springs. Most rubbing issues are at the rear wheels.
