245s and 255s club!!!!! Let's see what rims your on and how they clear!!!!!
#52
#54
I hope so for you. I've decided for my car. CF5 Forgestar 18x9 +50mm with Yokohama Advan Neova AD08 (but I saw the Toyo Proxes R1R, they seem to be really good, wondering if someone ever tried them). They should be perfectly flush.
#56
i ran the alleggeritas in 18X8 with a 245/40/18 dropped on stance coils and the fronts rubbed only on hard bumps at fast speeds. I had it lowered to the point where there was no gap between the tire and fender.
#59
#61
#63
Bottom line is that I want 18x9 with 255/35, I don't know how to set my coils not to rub and which offset I need to get so the wheels are flush with the fenders
#65
You and me both. Didnt matter the tune is all jacked up......hell the car basically ran the same times once off nitrous and another on. No worries the next one in Ennis mine will be sporting these bad guys!
#66
hes runnin 245/40/18 dstar specs on 18x9.5 with like +43 or something.
Last edited by Whining-devil; 12-16-2011 at 07:59 PM. Reason: Automerged Doublepost
#67
Hopefully by the event in Ennis, I will have some wider wheels for traction purposes lol.
l8r,
PD
#68
Going to try the spring event. Then hopefully be on a bigger turbo come the fall event.
#70
#71
Wow i would of bought the MT 275/40/17 5 months ago if i seen your car I have the 7" wide wheels but i was holding out till i had a proper wheel setup 9"-10" wide. How much Hp/Tq does your car make? I was more worried about spinning the rim and i hope it will hold traction in 2nd on the street without heating up the tires..
#72
#74
