anyone running +25 offset???????
Anyone running +25 offset????pics???found some rims
Unless they are 6" wide, it's not gonna happen. +38 to +42 is ideal.
Do it! Worst case you'll have to run some eibach prolines with a little roll and tug on the fenders, but, most likly just a little more roll.
Originally Posted by jboogie
(Post 5519962)
i'm running et29 but it's a 7" wide rim
Originally Posted by Bumpin Balt
(Post 5519995)
WTF is the point of running a crazy offset if you have to jack the car up to make them work? lol
they are 8.5 inches wide with +25 offset...so im guessin they wont work?:(
they may with a slight pull
Originally Posted by Ting-ting
(Post 5520269)
in the rear you can get the fender pulled so it flares out more
hmm would a +30 offset fit np then?
Originally Posted by Hockeyman
(Post 5520007)
you cant ask me lol to me yes it cant fit to picky people no
i wanna run 17x9 +30 maybe even lower |
(Post 5520305)
your correct for the most part but if you run a 15mm adapter your gonna have to cut the stock studs other wise they will stick out
(Post 5520310)
no what im saying is the stock studs will stick out threw the adapter cause 15mm is to small you would need a 20mm
(Post 5520323)
yeah they will stick out to far and will hit the back of the rim.well if you run 15mm you will have to put one one and cut the stud till it is flush with the spacer
and no if you cut stock studs you cant run stock wheels unless you put new studs in but studs are cheap like 1.50 each |
(Post 5520342)
no they are attached but they push out with a press or hammer and the new one push back in
oh damn nice! thanks alot for your help, now i just need to find out if the +30 offset with a 19x8.5 rim would fit without rubbing!!
oh hell no lol 19 will rub for sure
i thought we were talking about 17 |
(Post 5520373)
its hard to explain but yeah 19 will rub bad
