anyone running +25 offset???????
the reason why im throwin out these crazy ass numbers is b/c i can get a 5x110 to 5x114.3 conversion kit thats only 15mm thick, so if i would get a 5x114.3 aftermarket rim with a +45 offset(plus the 15mm conversion kit) it would ad up to a total of +30 offset... i am correct on this right? lol
so they will stick out and hit the rim that im putting on? and if i cut them how much do i need to cut them and if i wanted to put my stockers back on then the stock/cut studs would work?
yeah they will stick out to far and will hit the back of the rim.well if you run 15mm you will have to put one one and cut the stud till it is flush with the spacer
and no if you cut stock studs you cant run stock wheels unless you put new studs in but studs are cheap like 1.50 each
